Results 1 to 17 of 17
Thread: I snapped a Plenum Chamber bolt on the VS
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    Default I snapped a Plenum Chamber bolt on the VS
    Stupid me snapped a bolt on the Plenum Chamber
    So I am checking to find out if if I can replace the broken bolt or would I need a new Plenum Chamber?
    VS
    Jul 2010
    Sunshine Coast, Queensland
    Which bolt mate? Inside or the lid? Iv got all my spares from when i put my spacer and insulator in. To be honest, they look like a standard bolt.
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    More importantly, where is the rest of the bolt? Still in the inlet manifold? Can you remove it?
    No you don't need a new plenum. Whilst the plenum bolts are relieved in the centre and supposed to remain as part of the plenum, they can be removed by un-threading them out of their hole or vise versa for fitting a replacement.
    VX Commodore 2002 Executive v6. Ex Patrol Car
    Nov 2010
    Armidale, NSW
    James39's Avatar
    Jul 2009
    Newcastle NSW
    Good to know.. thanks for that info.
    Yeah the rest of the bolt is still in the inlet manifold Not sure how much thread is in it though... My torque wrench failed so i will have a look again when i get a new one hopefully this Sunday... I am sure it will not be hard to remove?
    So I can only get this bolt from a Holden dealer?
    VS
    Jul 2010
    Do you have a easy out kit? Used for getting snapped bolts out. Or even a reverse thread bolt/screw?
    VS
    Jul 2010
    Just dug through my bucket of VS bolts. Im going to guess its a seat bolt, its an allen key head, roughly the same length. Pack it up with some washers. That will do untill you get another bolt. See attached. Well you cant since i just killed my phone again
    James39's Avatar
    Jul 2009
    Newcastle NSW
    Quote Originally Posted by seq4x4 View Post
    I would have to get one.
    Looking down the hole on the plenum you could see where it has snapped off... Hopefully there will be enough there for me to use vise grips or something when I take the plenum off....
    James39's Avatar
    Jul 2009
    Newcastle NSW
    Thanks for that info
    VS
    Jul 2010
    Iv sent you a PM. Also i dont know if it was a seat bolt. I forgot some VK stuff got chucked in there. But not many other allen key bolts are in the commos that i can remember.
    James39's Avatar
    Jul 2009
    Newcastle NSW
    I have replied, thanks for all your help
    James39's Avatar
    Jul 2009
    Newcastle NSW
    I just torqued the remaining 4 bolts to 20 mn, do you think this should be ok?
    VS
    Jul 2010
    Iv never torqued my plenum bolts. But the plenum barly stays on it atm cause its on and off.
    Iv never had a leak before.
    Should bolt one of these on :P :
    Just about, roughly 5mm, from the casting marks in the manifold is where the plenum meets manifold.
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Quote Originally Posted by James39 View Post
    Service manual says 10-14Nm.
  15. #15
    James39's Avatar
    Jul 2009
    Newcastle NSW
    Quote Originally Posted by BlackVXGTS View Post
    Yeah I knew about that, but I did it higher to compensate for the snapped bolt lol
  16. #16
    James39's Avatar
    Jul 2009
    Newcastle NSW
    Does it help with performance?
    Mine needs a clean, but it is not that bad considering the amount of K's it has done...
  17. #17
    James39's Avatar
    Jul 2009
    Newcastle NSW
    All fixed today so I am happy
  1. gasket plenum chamber
    By shakey in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 17-04-2011, 02:32 PM
  2. cleaning plenum chamber
    By casper0 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-03-2011, 08:37 PM
  3. Plenum chamber
    By WJD634 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-05-2008, 03:26 PM
  4. Plenum Chamber Seals
    By andyman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-02-2007, 10:29 PM
  5. WTB: Ecotec plenum chamber (VS)
    By 2_SeeK_U in forum Swap / Wanted to Buy / Trade
    Last Post: 28-11-2005, 04:38 PM
