Results 1 to 17 of 17
Thread: vs v8 manual cruise control
    vs statesman
    Jul 2011
    sa
    Default vs v8 manual cruise control
    I have a Vs series 2 v8 converted to a t5 5 speed manual and I want my cruise control to work properly. Does anyone know what you have to do with the clutch pedal?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Welcome to the forum.
    You will have to instal a switch on the clutch pedal similar to the extra switch on the brake pedal. Because your car was an auto, it may not have the extra plug for the clutch switch so you will need to wire it in so it disegages the cruise when you put the clutch in. The wiring diagrams in the Gregorys manual do not show a clutch switch for some reason or other, but I'm pretty sure you must have one otherwise the revs would go thru the roof when you depressed the clutch.
    Edit....see this thread: cruise control in manual vn
    Disturbed_vegeta's Avatar
    Disturbed_vegeta is offline I'd Prefer To ROAR!
    Vs Statesman, Vr Senator 185I
    Dec 2005
    Burpengary
    I have the same problem with my senator. But the cruise control doesn't work at all. Anyone know why?
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    In my wagon i dont have the clutch switch at all. They are painful, especially in hilly areas where you wanna click between 4th/5th a few times. Having it cancel everytime you wanna change gears is just silly.
    Reaper
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Hako, the gregory's manual wont show it because there was never a factory released vs manual with cruise control.
    I think 'markovr' posted some info a while ago about retrofitting an additional stoplight switch to work off the clutch pedal that he did in his manual vr. I still need to do this myself.
    vs statesman
    Jul 2011
    sa
    Thanks I'll have to look into it further, but thanks for heading me in the right direction
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by cander24 View Post
    That makes sense - the link I included has the thread from markovr and covers how to fabricate the bracket and switch.
    Aug 2008
    NSW South Coast
    Quote Originally Posted by hako View Post
    Ahh, cheers! Thats the one I was thinking of. Should get onto doing this myself while it's on my mind.
    shanhsv's Avatar
    shanhsv is offline Luvo
    VS Berlina V8 5speed
    May 2005
    Muswellbrook,NSW
    My cruise has never worked since my manual conversion,and it still idles weird?
    WTB:VR/S HSV 250km/h speedo cluster
    vs statesman
    Jul 2011
    sa
    Hey guys,
    I've re-installed my cruise but now it's not working. The 'crs' light comes on but it won't set. The 'on' light flashes when I press the set button. Any ideas?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by STROKED_HSV_ST8TO View Post
    Hey guys,
    What cruise parts did you remove when you did the manual fit?
    vs statesman
    Jul 2011
    sa
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    So you've replaced the exact same one that was taken out?....any reason why it was taken out?.....sorry for the questions.
    vs statesman
    Jul 2011
    sa
    I have no idea why the previous owner had taken it out and yes I've replaced the exact same parts that were on the car
  15. #15
    vs statesman
    Jul 2011
    sa
    I've had a good look in the gregorys manual and also had a good look under the fuse panel inside the car and it looks like the switch for the cruise is gone. I assume that is why it doesn't work and the 'on' light flashes?
  16. #16
    Aug 2008
    NSW South Coast
    Bingo! With the stoplight switch removed (or even incorrectly adjusted) Cruise will not work. The crs light will stay on but when you try to engage cruise the'on' light will only flash as it will cancel straight away. I'd source another switch from a wrecker.
    Z' Series HSV 297KW 6lt LS2 Conversion For Sale!
    PM Me For Details
  17. #17
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Re the switch - just check that the previous owner has not simply bridged the connector that goes on the switch - I've seen this done to overcome a switch that keeps going out of adjustment. Also the CC module may have been buggered and then removed.
    Not sure if this is relevant but the other thing is that seeing as you have a Statesman, I think part of the switching for the CC is incorporated in the BCM....if this has been switched as part of the manual conversion you will need to add the CC relay under the fuse panel as fitted in low series BCM.....I'm probably totally wrong but just suggesting this FWIW.
  1. manual cruise control
    By david dubbo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-11-2009, 08:07 PM
  2. Man conversion-cruise control, will the auto cruise control work on manual conversion
    By pjdm1980 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-08-2009, 12:25 PM
  3. cruise control in a manual vr
    By tangooly in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-09-2008, 10:42 PM
  4. cruise control on manual
    By SaGe in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-04-2006, 08:40 PM
  5. Cruise Control in manual
    By Mr_Slim in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-07-2005, 11:51 PM
