Results 1 to 9 of 9
Thread: VR not turning over
    vr uterus
    Jul 2011
    downunder
    Default VR not turning over
    So the VR is not turning over i have cleaned the earths and batty is charged,,,,when i go to start it the dush brake light comes on??? Theres a click from a relay which is under dush which is brake relay,,,have changed it yet still no gooee goooee?
    have also unpluged at master cyc still no go yet brake dush light didnt work that time,,
    Bridged the plug with wire and still no gooee goee?
    help needed.
    Cheers.
    vr uterus
    Jul 2011
    downunder
    immobiliser???
    keys in it and on,so i am waiting 45min to see if that'll work.
    vr uterus
    Jul 2011
    downunder
    Nope the key thing didnt work... and looks like i maybe walkin 30kms to work tamorro,,,,HAHA
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Transmission in N or P ?
    All wires connected to starter?
    Battery terminals tight?
    Have you tried a jump start?
    Do the dash lights go dim when on 'crank'?
    Does that starter motor solenoid click.
    A charged battery thats collapsed will not be able to start the car.
    The brake light coming on may be just the 'globe test'. If so that's normal.
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    does the CEL come on, as suggested have a fiddle with the gear stick, maybe put another relay in the start relay to test it. If you get real desperate you can always short out the starter but leave that until the last resort.
    vr uterus
    Jul 2011
    downunder
    hi RX25SE
    Transmission in N or P ?,,,,,,yip plus fiddled with it to make sure.
    All wires connected to starter?,,,,,,yip checked that too
    Battery terminals tight?,,,,,,,,LOL yip!
    Have you tried a jump start?,,,,,,will do in morring when mate picks me up for work.
    Do the dash lights go dim when on 'crank'?,,,,,,nope, only that brake light flashes.
    Does that starter motor solenoid click.,,,,,,,nope noone home down there.
    hi VK SL 3800
    Whats CEL? did a relay swap and still didnt help.
    Maybe i'll should just beat her with the FBH!!!!
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    vt 5.7 6 speed
    Jul 2011
    newcastle
    Take out the starter relay and plug in a piece of wire across the pins that the relay turns on and off needle nose pliers work great to.
    The pins are labelled on the side of the relay the lines with a dot on the end NOT the coil of wire symbol there will be numbers on the side and bottom of the relay.
    This is Just to test the starter motor.
    You should use the wire as a key START don’t leave it connected.
    Make sure you have the key on as if it was running the red lights on the dash this should start the car.
    It does sound like park safety switch or starter.
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    Sounds like you have a stuffed Starter Motor or a Stuffed Starter Motor Solenoid.
    If it's not a Symptom its not relevant, and if its not relevant I don't care!
  1. Accessories turning on by itself after turning car off
    By Danny40 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 01-04-2011, 11:04 AM
  2. ESP turning off
    By ascottaudio in forum VE Holden Commodore (2006 - ?)
    Last Post: 23-06-2009, 10:23 AM
  3. indicator not turning off when turning corner
    By jared_vn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-03-2009, 11:11 PM
  4. My Car Keeps Turning Off
    By CastorTroy83 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-11-2008, 03:37 AM
  5. My Car Keeps Turning Off
    Last Post: 31-08-2008, 09:39 PM
