Results 1 to 9 of 9
Thread: eibach springs
    VS V6 Station wagon
    Jul 2011
    central coast
    Default eibach springs
    have just bought a eibach pro kit 30-40mm lowered and in need of suggestions for good struts / rear shocks to suit my VS wagon.I have a whitline front bar and lower control arm mounting kit to fit as well.
    VS
    Jul 2010
    Sunshine Coast, Queensland
    Never heard of that brand before. What size wheels do you have? That 2 iv used and will recommend are monroe and pedders. You did also get a strut brace and a adjustable pan hard rod?
    Just a thought since your taking the struts out.. Do the strut top bushes and bearings. I have a how to on all this if your interested.
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    With those springs I would use Koni shockers.
    Just the normal oil (red ones). These can be adjusted out of the car, 5 stages, rebound only.
    These will ad some 'tunability' to the setup but I find they work best straight out of the box.
    IIRC the fronts will require some cutting and drilling to fit (not that hard) as they are a cartridge type insert rather than the whole leg.
    VS V6 Station wagon
    Jul 2011
    central coast
    thanks, didn't think about the all the other stuff in particular the brace and panhard rod.eibach are german made and are cheap at the moment to suit the VS.Lowndes runs this brand in the V8 supacars.have 16 X 7'S with 215 X 60 series C drives at present.cheers
    VS V6 Station wagon
    Jul 2011
    central coast
    VS
    Jul 2010
    Do you have a link for a site that does Holden. Their main one does not mention Holden.
    Have a gander at this site for a how to with monroe. How to: New struts and/or springs: Commodore - Motordrenaline
    VS V6 Station wagon
    Jul 2011
    central coast
    eibach direct is the website i bought off,couldn't link it for you.thanks for yours.cheers
    RX25SE's Avatar
    vsII acclaim wagon
    Jan 2009
    I would forget gas shockers.
    Koni oil are waaaay better than KYB adjustable gas.
    VS V6 Station wagon
    Jul 2011
    central coast
    good advise, along with the panhard rod should adjustable top trailing arms be fitted for pinion angle?the tail shaft on these wagons don't like being at awkward angles?,thoughts?
  1. [NSW] WTB VU front v8 struts/springs and rear springs standard height
    By dreammist in forum Swap / Wanted to Buy / Trade
    Last Post: 23-12-2010, 11:55 AM
  2. [VIC] Fs: Ve hsv eibach maloo springs
    By glenn l in forum Parts And Other Items For Sale
    Last Post: 14-12-2010, 04:18 PM
  3. King Springs low front springs, are they lower then FE2?... oh and the rears..
    By mike49 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-07-2010, 07:32 PM
  4. [QLD] swap Solid axle springs for IRS springs for the rear - Goodna
    By Gus The Snail in forum Swap / Wanted to Buy / Trade
    Last Post: 10-04-2009, 07:59 PM
  5. FS: Whole Suspension Setup (Springs , Shocks, Struts) King Springs
    By ssmate in forum Parts And Other Items For Sale
    Last Post: 01-11-2007, 06:24 PM
