Results 1 to 10 of 10
Thread: VR V6 auto TO Manual Conversion
    VR Calais
    Mar 2011
    Plumpton
    Default VR V6 auto TO Manual Conversion
    hey guys not to sure if this has been discussed but what would be my better option
    Change the Manual Harness to the VP one i got with my manual conversion or have my memcal reprogrammed to suit manual ?
    right now iv removed the engine light ( bad thing i know ) so i cant see it but now if i remove my battery it will run fine for a week, then a week goes by and then the revs sit at about 1200RPM, then about 2 weeks later the revs will drop down to about 300RPM
    anyone got any suggestions or info that could help me pls
    1993 VR CALAIS 5 SPEED MANUAL,Lowered all around on pedders, 20 inch G8s, Option audio front splits, option audio amps, sound stream subs, pace maker extractors, high flow cat, 2.5inch lukey cat back exhaust
    VR Calais
    Mar 2011
    Plumpton
    Anyone ;(?
    VR Calais
    Mar 2011
    Plumpton
    Bump back to the top
    My mate said something about limp mode?
    It's only since I converted it
    ve ssv/vr calais V6 turbo oneday N/A Track car
    May 2010
    Rockhampton QLD
    When i did my converson i changed the engine harness and ecu to suit the manual. The manual harnness wont plug it to your auto ecu.
    do you have the manual ecu for it?
    May 2010
    Rockhampton QLD
    VR Calais
    Mar 2011
    Plumpton
    I got the harness and ecu but their out of a vp exec, am I going to have any dramas changing my the harness cause mines a berlina?
    May 2010
    Rockhampton QLD
    Dont think so mate mine was a calais and i had no probs there was just a cam sensor that had to be left un hooked because the manual harness didnt need it everything worked fine.
    VR Calais
    Mar 2011
    Plumpton
    Apparently there's 2 plugs near the fuse box that might be a pain and need to be re wired, could this be true?
    May 2010
    Rockhampton QLD
    not that im aware of i didnt have any trouble the should be a black 5 pin and a grey 7 pin plug that goes over near the fuse box might pay to lay your harness out and check off each plug and where they go to see if any will give you trouble. There should be a Alternator, starter and earth wire that gose over to your battery as well the rest will loop around the engine and in to the passager side of the fire wall to the ecu
    VR Calais
    Mar 2011
    Plumpton
    Found out my problem the ecu was in limp mode or limf mode? I had all the auto codes turned off an the idle turned down to 850 so all should be good for now
  1. [VIC] T5 Manual G/box out of 88 VN Wagon. Everything for full Auto-Manual Conversion
    By Shaz77 in forum Parts And Other Items For Sale
    Last Post: 11-06-2011, 04:05 PM
  2. VR auto to manual conversion!
    By SportsVR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-03-2011, 06:38 PM
  3. PCM BCM vt auto to manual conversion PLEASE
    By bencbh in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-11-2010, 02:47 PM
  4. Please Help, Doing manual conversion and i used the auto flexplate bolt on manual fly
    By xtreme_sony in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-06-2009, 08:52 PM
  5. Vp manual conversion and vn auto conversion
    By gumbs in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-06-2005, 11:08 PM
