Ok so I recently replaced the old tired motor in my vR acclaim I have both radiator main hoses conected but where do the little ones go? The translines have their own cooler and I'm stuffed if I know what the go is, can someone please help
if your transmission has its own front mounted cooler, dont worry about the little ones on the radiator. normally thats the trans cooler, altho, you could use it as a P/steering cooler if its getting hot at all....
I also make Electronic Dance Music
http://www.youtube.com/user/klampykixx?feature=mhee
At the moment I hve it running from one epot in h radiator back th other smqll hose spot an its preventing
Water from cirulating properly. Any ideas?
id have a better idea if i could read what you just typed (twice)
Yeah sorry about the off typing, two small lines are just running too each other, will this still work fine?
You can leave them as they are they don't need hose on them or anything water doesn't come out of there.
Beautiful thanks wraith
yea, what he^ said.
Thanks guys your both life savers
