Results 1 to 5 of 5
Thread: VS V6 cruise control not working!!
    VS V6 Ecotec Wagon
    Jul 2011
    Mooroopna Victoria
    Default VS V6 cruise control not working!!
    hey guys,
    recently my fuel gauge was sticking so i hit the dash and the lights went out, all headlights dash lights ect. i found a plug in the kick panel that had come unplugged..
    i asked an auto alec what the green wire going into that plug was for and he said it was cruise control wire or something tapped into the plug, now everything is working fine just not cruise control! it worked fine beforehand.
    any suggestions ??
    cheers
    VY Executive S2/ VY SS 6sp
    Jan 2011
    Western Australia
    check fuses a lose plug can cause spikes that could blow a fuse so check all fuses and make sure the plug it connecting proply
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Does the 'crs' light come on?
    VS V6 Ecotec Wagon
    Jul 2011
    Mooroopna Victoria
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by Macdizzle23 View Post
    yeah crs light comes on
    Then you need to check the cruise cutoff switch located above the normal brake switch at the top of the brake pedal....if it has moved (and they do), cruise will not engage as it thinks you have the brakes on. Also check the brake light bulbs.
  1. Cruise Control not working
    By Ray De Man in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-04-2012, 08:49 PM
  2. vn cruise control not working....
    By noyzv8 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-12-2010, 10:51 AM
  3. cruise control not working
    By cohn in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-12-2010, 06:50 AM
  4. cruise control not working -vr
    By stormsearcher in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-12-2010, 09:05 AM
  5. Cruise control not working
    By Crossy_014 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-10-2009, 09:31 PM
