Results 1 to 3 of 3
Thread: VS auto not down shifting correctly
    97 VS S2
    May 2011
    Default VS auto not down shifting correctly
    Hi,
    I've only had my car a few months, and only noticed that when slowing down and rolling around a corner, it won't change back into 2nd gear. It'll stay in 3rd and won't kick back to 2nd until I start accelerating again. If I slow right down until I'm almost completely stopped, it will change back to 2nd. If I come to a complete stop, it'll change back to 1st no problem.
    I'm not getting any fault codes coming up.
    Any ideas? TPS maybe?
    VS Wagon
    May 2009
    Wollongong, Australia
    did you find the problem by any chance?
    I think i have the same problem. I have a stage 2 with upgraded servos, drum, shell ect ect ect and every now and again it wont downshift. but it will downshift when i tap the accelerator.
    I have tried searching online but everytime someone has asked about it everyone jumps up and tells them how stupid they are for manually changing gears in a auto but no one tries to give suggestions.
    Its a frastrating problem
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    You could try changing the Throttle Position Sensor or get the change points altered in the ECU by someone like The1 who is on this forum - Commodores have their change points set much lower than most other cars due to the engine characteristics etc so they can be less responsive unless you put the boot in.
  1. auto shifting
    By drippy in forum VY Holden Commodore (2002 - 2004)
    Last Post: 16-09-2009, 08:59 PM
  2. VS Auto Transmission not changing correctly
    By SteveHow in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-02-2008, 01:45 AM
  3. auto shifting early?
    By starfire vc in forum VL Holden Commodore (1986 - 1988)
    Last Post: 13-09-2007, 04:35 AM
  4. auto shifting
    By shumway in forum V6 Development And Modification
    Last Post: 31-01-2007, 06:05 PM
  5. auto shifting
    By bigbos in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-12-2005, 07:59 PM
