hi having some trouble with my ute.
Its running very rough in idle and worse while driving and has lost alot of power. ive done every check i can think of and cant figure out what it is. and there is no error code showing.
Can anyone help please
Have you filled it up with fuel lately? Perhaps bad fuel.
Could even be bad spark... Or another 100 things...
yer i filled up a week ago. it worked beautifully for 3 days, went to leave for work next morning and its been running like shit since
I dont know what test you did but check fuel pressure. How old is your fuel filter that might need changing.
Also check some of the vaccum lines in the engine bay.
This may help with diagnosing the problem. now i have white smoke coming out of the exhaust
it first started as light smoke when i was sittin in idle for a while and it got really thick and white after a couple mins waiting for traffic to move. pulled over and left car turned off for 15 mins and continued home. got a little bit of smoke on the way but not very thick. havent risked turning it on again since![]()
that seems like a gasket/seal has gone somewhere.
Is it an Auto? Before you start pulling apart you engine have you looked to see if the transmission is leaking? This happened to a mates car the other week and the tans fluid was leaking onto the hot exhaust causing smoke and a loss of power. Start by checking your fluid level but make sure the car IS running when you check it.
its a manual. engine and gearbox have no leaks and no water in the oil. kinda spells like fuel when there is smoke.
