Results 1 to 6 of 6
Thread: Things i need to buy for clutch change
    1999 vs ute series 3
    Oct 2009
    Default Things i need to buy for clutch change
    ok as the title says im changing my clucth over the weekend.
    Series 3 vs ute getrag box.
    Ive got clutch and flywheel thats it. ive never done a clutch before but i got mechanic mates wich will help me out. I just want to no what exactly what i need to by extra.
    cheers,
    Quote Originally Posted by Jonnii View Post
    yeah well it is a ute its not supposed to be about comfort
    http://forums.justcommodores.com.au/...rst-car-d.html <<< My 5sp vs ute
    VY SS
    May 2011
    Auckland
    Haunt done mine yet but looking into it.
    you will need:
    Brake/clutch fluid
    Gearbox fluid
    I'd do the release bearing while your at it too.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    What about the spigot/pilot bearing....they rarely fail, but can do, and are cheap and easy to fit when doing the changeover.
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Thrust bearing and new flywheel bolts, new pressure plate dowel pins if the getrag uses them?
    Power is measured in DECIBEL
    Oct 2009
    okay
    brake/clutch fluid i have.
    tranmission fluid i change about 2,000k ago can i drain this on a clean bottle and re use? as long as there are no shavings or parts that should not be in a gearbox :/
    thrust bearing and spigot bearing will be purchased
    why flywheel bolts? the exact same flywheel will be going in.
    thanks for the help
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    Quote Originally Posted by MADDNE33 View Post
    okay
    thanks for the help
    Flywheel bolts are torque to yield, the threads will be stretched and wont clamp as well used second time around
  1. Clutch and Change Q
    By madsav in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-03-2011, 08:32 PM
  2. How to change clutch fluid
    By newtownbob in forum VY Holden Commodore (2002 - 2004)
    Last Post: 22-04-2008, 08:38 PM
  3. can i change the rear things myself?
    By ryan_VX in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-11-2006, 07:38 PM
  4. how to change a clutch
    By canb_vn06 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-06-2006, 01:00 PM
  5. Replies: 2
    Last Post: 30-08-2004, 09:58 PM
