Results 1 to 4 of 4
Thread: VT auto into a VS?
    '95 VS Executive BT1
    Oct 2010
    Woori Yallock, Victoria
    Default VT auto into a VS?
    hey all, i've been a member if this forum for a while and ive only recently found it again. The stock auto in my Series 1 '95 VS BT1 has finally shat itself. My stepbrother has bought a VT S-pack 5spd manual for the parts, and i was wondering if the VT auto would fit in the VS?
    Any help would be greatly appreaciated.
    Thanks, FlameFury
    "If in doubt, get the hammer out"
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    Yes it will fit, but you will need to grind away some of the bellhousing as the exhaust will foul on it, torque converters will need to be changed, ECU and PCM will need to be changed as well.
    If it's not a Symptom its not relevant, and if its not relevant I don't care!
    Oct 2010
    so in other words, its not worth me doing it cos, frankly, i know sh!t all about the mechanics of cars. i just fix the ones that crash. haha
    FstStig's Avatar
    1993 VR Calais
    Sep 2008
    All depends on how much time you have on you're hands. They are a stronger box then the VS as they have stronger internals and this is why people go through the trouble to put them in. You may also have to do some modification to the wiring harness as I think the VS Plug using a 6 pin and the VT uses a 7 Pin.
  1. VE SV6 200 H0 Motor Auto 2008 Transmission Change of Auto oil
    By markholland in forum VE Holden Commodore (2006 - ?)
    Last Post: 31-01-2011, 05:24 PM
  2. Replies: 7
    Last Post: 21-07-2010, 10:45 PM
  3. difference between standard auto and turbo auto
    By Nackerz in forum VL Holden Commodore (1986 - 1988)
    Last Post: 27-11-2009, 08:56 PM
  4. Fuel Mileage Holden VZ Wagon(auto) Vs Subaru 2.5(auto)
    By phantomwalker in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 29-06-2008, 06:38 PM
