Results 1 to 14 of 14
Thread: help with blowing my brains out *holds out gun* engine knocking..
    Calais V6 3.8
    Mar 2009
    Default help with blowing my brains out *holds out gun* engine knocking..
    well im going to swear alot i bought this 94 vr commodore slammed on its arse hsv kit, bald tyres un captive springs, brake hose leak, 4 grand i bought this piece of shit for because it look quite quite just cosmetic but perfect for a 3 or 4 year long project. regret paying 4 thats for sure!! anyway.
    its just started knocking (yay) knock knock knock on idle from the front bottom, no knock perfect runner when throttle is in slightly or hard. any ideas of where to start looking? cheers.
    suicidal commie lover.
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Calais V6 3.8
    Mar 2009
    ima go quickly check and take a video see if anyone can identify...the noise is coming more from the bottom then balancer. thats the pulley to the left of alternator and right of power steering correct?
    304runner's Avatar
    304runner is offline ( .Y. )
    VR 5.0 Ute & a 4runner with a VS SS trasplant
    Mar 2011
    Central Coast NSW
    Yeah id almost guarantee its a a sticky lifter. Does you oil light flicker? Not that that it wouldn't happen if it didn't come on. Change the oil to a thicker grade and see if it still happens. Cheap way to eliminate an issue and can only do your car some good...
    Hangman's Avatar
    Hangman is offline Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    Quote Originally Posted by bad_vn View Post
    No, the balancer is the big one down the bottom. The rubber piece joing the inner and outer sections goes on them. With the car running, look at the pulleys from the side and see if there's any movement.
    Water pump bearing is another possibility.
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    As BlackVXGTS says, harmonic balancer - check by removing the serpentine belt - if knock goes away then that's the problem. You might also be able to see it wobbling at idle. The harmonic balancer is the large pulley at the very bottom of the engine and bolts to the end of the crankshaft....it has a rubber centre that eventually shears.
    jayperformance is offline light it up
    vn Calais 5l
    Jul 2011
    griffith
    with the engine off you try and turn the pulleys/belt with your hands if it turns half and inch either way with not much resitance, its your harmonic balancer.
    Calais V6 3.8
    Mar 2009
    i thought that was the crank pulley just a different name i presume lol. will check after work cheers guys.
    Calais V6 3.8
    Mar 2009
    Calais V6 3.8
    Mar 2009
    Calais V6 3.8
    Mar 2009
    haha well what the f*** do ya know. im %100 guessing that the rubber inside the crank pulley is all meant to be there because if its not mine is missing a huge chunk out of the 'harmonic balancer'... so i presumming thats the knocking noise. how does it make such a devestating noise just by loosing a bit of rubber?
    another question is there any precatuions putting a new harmonic balancer on? just slap on rattle up and off ya go?
    1994 vr commodore hsv body 17'' powdercoated rims, lowered on superlows, tinted, sounds, black topped. turbo project in the making.
    1996 VS BT1 SS 5ltr original
    Apr 2008
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    You're Harmonic Balancer is there to do exactly as the name describes to take the Harmonic's out of the motor (Or vibration if you like), they use rubber to do this, so if the rubber breaks away, then you are going to start to have knocking and or vibration noises. That is not to say other things can't throw out the exact same symptoms. You will need to remove you're thermo fan (4 10mm bolts and unplug the electrical connector) You can try and use a rattle gun, if not get a breaker bar with the 22 or 24mm socket (can't remember which one), then get a long piece of pipping and rest the end of the pipe on the ground (on the drives side).
    Give you're motor a few hard cranks, don't let it start. If the bolt doesn't crack, start the motor for a split second then turn it off. This will crack the bolt for sure. You will need to get a 150mm Harmonic Balancer puller from supercheap or repco. Loosen off the bolt, but don't take it out, put the the 3 jaws evenly around the Harmonic Balancer and start to wind in the center bit on the Puller. You will need to get a socket or spanner to help wind it in.
    If it's not a Symptom its not relevant, and if its not relevant I don't care!
    Calais V6 3.8
    Mar 2009
    Thanks guys
  1. 304 Holden 5.0L Engine Knocking
    By st11xy in forum V8 Development and Modification
    Last Post: 04-03-2011, 10:43 PM
  2. vt engine pully knocking
    By weazzellboi in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-03-2010, 10:52 PM
  3. Engine Knocking at Idle..
    By jtyoss in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-03-2009, 08:24 PM
  4. Engine Knocking so i need another
    By DArtaganan21 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-02-2009, 05:20 PM
  5. Engine knocking
    By d_neo_b in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-01-2009, 10:09 PM
