Results 1 to 5 of 5
Thread: VR Commodore Strur bar to Chassis mounts
    VR Executive 3.8
    May 2011
    Post VR Commodore Strur bar to Chassis mounts
    Hey guys, any feedback would be awesome including pics on way i would go about changing these, but am a stuck as to which bushes these are?
    Also I have bushes for strut bar to lower control arm and control arm lower inner bushing kits...
    the worst part is that i cant find where these are supposed to go and want to get these done asap, all help would be appreciated
    vr v8 calias
    Jul 2011
    victoria
    VR Executive 3.8
    May 2011
    yeah its for roady and have no clue which ones they are as the mechanic didnt explain which ones they were at all
    VS UTE, HT MONARO REBUILD
    Dec 2010
    if the strut bar is also called the radius bar which im pretty sure it is, then have a look at the bottom of your front suspension setup and you will see a bar that goes from the control arms and bends around into the chassis, this is the arm, the chassis bushes sit into the chassis it's self and the cntrol arm end sits into the control arm, here's two pics off the nolathane website
    Hope this helps mate, also best if you get a professional to change them out for ya.
    VR Executive 3.8
    May 2011
    thanx mate for this, i will have to have a look and go from there
  1. VN Commodore 3.8l transmission mounts???
    By PUSHIN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-02-2011, 10:56 PM
  2. VH chassis code
    By magnetvh in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-01-2011, 08:32 AM
  3. [SA] WTB: VS OR VU ute rolling chassis
    By piston1 in forum Swap / Wanted to Buy / Trade
    Last Post: 25-05-2010, 06:37 PM
  4. chassis & serial numbers vc commodore
    By nathankras in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 14-03-2010, 10:41 PM
  5. Is the VIN or chassis number stamped on the actual chassis ?
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-12-2005, 08:49 PM
