Results 1 to 14 of 14
Thread: motor will run for 5 seconds then stop
    VR Commodore bt1 5speed
    Jul 2011
    Bankstown
    Default motor will run for 5 seconds then stop
    Hi boys I was driving along when my car started coughing an splatting so i give it the gas an a flat spot wont even rev feels like its out of fuel so i put in $30 changed the fuel filter now it wont start when it does runs only for bout 5sec then cuts out even when i try an give it a rev anyone had this problem an fixed any comments will be great VR BT1 5speed
    Nobody Actually's Avatar
    Nobody Actually is offline luxo barge
    VS s2 Caprice 5l = slow
    Aug 2005
    Queensland
    Hangman's Avatar
    Hangman is offline Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    My money's on fuel pump. Try giving the bottom of the fuel tank a few hits with a rubber mallet or similar and see if that does anything. Hard but not to hard though.
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
    Jul 2011
    Bankstown
    Jul 2011
    Bankstown
    turned key to on didnt hear anything after changing filter
    Quote Originally Posted by Hangman View Post
    Hangman's Avatar
    Jan 2010
    Good chance it's the pump then if you can't hear it priming when you turn the key on.
    VR Series 2
    Jul 2011
    NSW Nth Coast
    deff the fuel pump...... should sound like a mozzie in a tin can whilst priming...
    Jul 2011
    Bankstown
    thanks boys will go buy one 2morrow
    Quote Originally Posted by bennbeck View Post
    vx s pack II
    Jan 2010
    aLKIDA
    Thumbs up
    Dont guess work do tests.
    First of check fuel pump circuit fuse, The ECM signals the fuel pump relay to energize so check for power at the relay base when reds are on if there is no power then the ECM is at fault.
    check fuel pump relay is energizing.
    If this checks out fine then check fuel pressure to see if the pump is working. to spec
    If this is all ok your problem lies some where else.
    People just because the fuel pump does not turn on it does not mean the actual unit it self is not working.
    drewVHSS's Avatar
    drewVHSS is offline Donating Member
    '83 VH SS, '79 Malachite Green VB SL '91 VQ Stato
    Apr 2010
    Gosford Central Coast
    also, fuel pump wont be allowed to run if the ecu doesn't see any oil pressure. I usually remove this when i wire in efi into an early holden so cust can retain original oil pressure gauge.
    just another thing to check
    vx s pack II
    Jan 2010
    aLKIDA
    Quote Originally Posted by drewVHSS View Post
    You will find that the fuel pump relay is a change over relay. If the ECM see's there is oil pressure and the starter relay does not energize for what ever reason.
    The fuel pump can still work. There is a bypass circuit from the oil pressure switch circuit. So by you removing this option has the reverse effect as well.
    So what i am trying to say is if the relay fails there is no back up circuit for the fuel pump now.
    This is Assuming you have open circuited the oil pressure link to the fuel pump circuit.
    drewVHSS's Avatar
    Apr 2010
    I've always rewired from scratch and eliminated everything possible so there's less headaches, I didn't realise the full intent of how they're originally wired. I just saw in the wiring diagrams that the oil pressure switch had control of the fuel pump side of things and most of the conversions I've done required a pressure sender for the dash so i eliminated the switch in the assumption that without oil pressure the fuel pump wouldn't run.
    Sorry if i've given a bum steer of sorts.
    vr commodore 3.8
    Jul 2011
    perth
    ive got same problem happened in about the same way... 205,xxkm 1/4 tank ran like shit wouldn't respond to revs died wouldn't start, no whirling sound from pump haven't solved it and its doing my head in
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    Quote Originally Posted by BONED-VR View Post
    Have some patience; I am sure someone will reply to the thread you started…
  1. vt stopping after idling for a few seconds
    By daze in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-07-2011, 06:39 PM
  2. Mazda's new Motor - Idling Stop Technology
    By FstStig in forum The Pub
    Last Post: 15-03-2011, 09:45 PM
  3. 0 to 200 in 6 seconds
    By madnuts in forum Jokes/Humour
    Last Post: 17-04-2010, 01:52 PM
  4. 0 To 200 In 6 Seconds
    By Dirbatua in forum Jokes/Humour
    Last Post: 10-02-2008, 02:52 PM
  5. vp 0-100 6 seconds flat WTF
    By vks in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-02-2007, 08:39 PM
