Results 1 to 8 of 8
Thread: heat constantly on, cant get cold to work and engine fan turning on earlier than norm
    VS V6 Commodore series 2
    Mar 2010
    Default heat constantly on, cant get cold to work and engine fan turning on earlier than norm
    gday i just had some stereo guys fix my system and on the way home i noticed my thermostat showing a lower temperature than normal on my dash, then i also noticed even when i spin the dial for climate its always blowing warm air out, so i pulled the dash apart and noticed a gal rod with a thread on the end dangling doing nothing, had a look around but cannot find where it needs to go, can someone point me in the right direction with a previous thread? i did have a quick hunt but found nothing other than 'fans wont stop'
    also my engine bay fan kicks on where my normally my thermostat would sit while driving (between quarter and half on the smaller of the 2 lines)
    was wondering if these 2 problems are linked or whether my themorstat could be indicating an un-true reading.
    do realise tho as long as the fan is kicking in im pretty safe from overheating or any thing like that.
    cheers guys
    VR Executive 3.8
    May 2011
    Hey MGNick, if you look on the drivers side next to the footrest in a sense you will notice that there is a lug that moves slightly with a clip but what i will do is go out and take a pic so that you can see what it looks like
    VR Executive 3.8
    May 2011
    Mar 2010
    holy shit...i just went to my car cos no1 was giving me some info....so i tohught stuff it ill try it myself.....and i didnt see one of those...i hope they didnt break it on me while pulling out the climate control...ill be so shattered
    thanks for the pic tho!
    VR Executive 3.8
    May 2011
    May look a bit different to the 1 i have posted for you as climate control will be slightly different but if you can follow the galv piece back to where it is and you may be able to find where is goes straight away, just make sure to play with the dials
    Mar 2010
    perfect! all sorted! thanks heaps mate never would of found it without ya
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    [QUOTE
    Hope this helps[/QUOTE]
    Is that a drop of green coolant under the vacuum switch?.....looks awful like one. If so, your heater is leaking.
    VR Executive 3.8
    May 2011
    yeah it is Hako and i only noticed that thanks to myself taking that photo so time to look at it and sort it out asap
  1. my thermofan runs constantly even when engine off
    By TonyJZX in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-12-2010, 08:01 PM
  2. engine heat
    By bars1979 in forum General
    Last Post: 07-05-2007, 06:11 PM
  3. top plate on front strut sits alot higher that norm
    By buzurk in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-03-2007, 01:03 PM
  4. Engine Bay Heat
    By VN_Luke in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-12-2006, 10:09 PM
  5. no heat nz cold lol
    By pike in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-04-2006, 07:48 PM
Tags for this Thread
