Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By darcycammo
Thread: VS V6 coolant leak from the bypass hose?
    VS SII Esteem
    Sep 2009
    Default VS V6 coolant leak from the bypass hose?
    Hi guys, have recently replaced almost my whole cooling system including radiator, hoses, water pump and heater tap. I have just noticed a fresh leak coming from the heater bypass hose fitting where it joins the pump. Before I take the hose off, is this just an o-ring seal? I just need to know what to buy before I pull it apart.
    Attached Thumbnails Attached Thumbnails VS V6 coolant leak from the bypass hose?-dsc00144.jpg
    Did have VS Berlina now have VT Berlina
    Mar 2010
    Cockatoo Vic
    VS SII Esteem
    Sep 2009
    Cool thanks for that, off to supercheap or autobarn for me tomorrow, I probably would have one at work that would do but seeing as I've done the rest of the system properly I might as well get the right one for the job, thanks again
    Mar 2010
    Cockatoo Vic
    here is a photo of the rubber seal on the metal pipe
    here is a photo of the rubber seal next to a 22mm shifter
    VS Berlina/ KJ Verada
    Sep 2006
    Holden charged me $13 for both those heater Orings.
    95 VS Berlina
    http://forums.justcommodores.com.au/...ml#post1891856
    I need some statesman/ calais woodgrain for drivers side panel!!
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    If you are lucky it will only be the "O" ring that needs replacing, if unlucky it will be a corroded casting. Seeing as you have had to replace so many other cooling system parts, I'd wager on this being buggered too. Sorry for being negative but it's best being forewarned. Hope I am wrong.
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Quote Originally Posted by hako View Post
    nothing pumping it full of slazo wont fix
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by VK SL 3800 View Post
    That sounds interesting...what exactly is 'slazo' ?
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The best I've found is Sikaflex...not sure the exact version but this stuff is black and takes about 3 days to become reasonably stiff, sticks to any clean surface like s**t to a blanket. If you do proper preparation, the joint will never leak. Used plenty on my daughters KC Laser....even stopped it leaking from where the distributor goes.
    VS SII Esteem
    Sep 2009
    Well 50c later and no more leaks, Oring was stuffed, placed a new one in there and presto, had to try a couple of different sizes but found one which fit perfect (not the one pictured), thanks guys
    Attached Thumbnails Attached Thumbnails VS V6 coolant leak from the bypass hose?-dsc00146.jpg   VS V6 coolant leak from the bypass hose?-dsc00147.jpg
  1. [General] [Buick]"How To" bypass hose and inlet manifold bung
    By LeaThaL in forum Holden Commodore How-To's
    Last Post: 08-04-2012, 10:24 PM
  2. replaced radiator and bypass bung, now coolant leak from timing cover... uh?
    By VRcommondoor in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-05-2011, 04:07 PM
  3. VX Coolant leak from Coolant Reserve?
    By anarklov3r in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-09-2010, 09:50 AM
  4. Transmission Hose Leak
    By Mk III the HSV in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-02-2008, 09:19 PM
  5. Question re bypass coolant hose on VP Commodore
    By Frogman in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-02-2008, 01:33 AM
