Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By vps231
Thread: Vr v6 auto
    vr commodore 3.8
    Jul 2011
    perth
    Default Vr v6 auto
    My cars 94 vr v6 auto 205,000km serviced regularly good battery 1/4 tank of gas stock standard. i was driving for a good couple hours that was fine pulled into my brothers went to drive off home then she died as i was driving. Tried starting her she turned over ran like shit then died. after a couple hours sitting she still wouldn't run at all. Towed her home changed coil packs nothing happening.. Did some reading am thinking crank angle sensor maybe or ??? please help need my vr going asap
    Vp S IRS 6 Banger
    Jul 2009
    vr commodore 3.8
    Jul 2011
    perth
    vr commodore 3.8
    Jul 2011
    perth
    VS Stato l67
    Mar 2009
    Melb
    Quote Originally Posted by BONED-VR View Post
    how do i check fuel pump isnt it a intank model ?
    You should be able to hear it working. If you cant, then it could be rooted
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    You can also loosen the fuel filter - if fuel sprays out the pump is working...if it dribbles or nothing comes out the pump is buggered. Do this within a few minutes of trying top start the car...you can also give the bottom of the tank a good thump with your open palm - this can start them up again.
    Vp S IRS 6 Banger
    Jul 2009
    Just get under the car at the back and get someone to turn the ignition on. U will hear it if its working.
    Vp S IRS 6 Banger
    Jul 2009
    Did ya get it sorted mate?
  1. VE SV6 200 H0 Motor Auto 2008 Transmission Change of Auto oil
    By markholland in forum VE Holden Commodore (2006 - ?)
    Last Post: 31-01-2011, 05:24 PM
  2. Replies: 7
    Last Post: 21-07-2010, 10:45 PM
  3. Changine from Column Auto to Floor Auto
    By VNCPTR in forum General Discussion
    Last Post: 16-04-2009, 01:48 AM
  4. Fuel Mileage Holden VZ Wagon(auto) Vs Subaru 2.5(auto)
    By phantomwalker in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 29-06-2008, 06:38 PM
