Results 1 to 5 of 5
Thread: how to install a towbar in a vr sedan
    94 vr executive
    Jul 2010
    queensland
    Default how to install a towbar in a vr sedan
    hey guys,
    can anyone give me a detailed explanation on how to install a towbar on a vr sedan. the bar is a hayman reese 1200kg
    thanks in advance guys
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    It should have come with instructions unless it is second hand.
    You will need to remove the bumper and the boot carpet. There are dimples in the boot just under the two curved sections of the sound deadening on the front of the boot looking at it from the back of the car. You will need to drill those out. The fitting kit will have a plate, crush tubes and long bolts, these go in through those holes, then the fit the towbar up from underneath hanging it off those two bolts. Hold it up with a jack or an axle stand so that it sits firmly against the car. Fit the washers and nuts to the two bolts but do not tighten them yet. Drill the bolt holes from the back and under the back where the plates line up on the car. Fit the plates on the inside and the bolts and washers. Tighten all bolts.
    That is how it fits up from memoery, it's been a while since I have done a standard Hayman Reese bar.
    Visit my Facebook page
    94 vr executive
    Jul 2010
    queensland
    ok cheers, i pulled the bumper off and the boot carpet out this arvo, so i'll give it a go tomorrow and see what happens
    thanks
    94 vr executive
    Jul 2010
    queensland
    94 vr executive
    Jul 2010
    queensland
    ok i found the dimples, i just had to strip off a bit of tht sound dedening stuff
  1. VE sedan towbar
    By Shorty33 in forum VE Holden Commodore (2006 - ?)
    Last Post: 17-12-2011, 04:36 PM
  2. [SA] WTB VZ Sedan Towbar
    By Tuttle in forum Swap / Wanted to Buy / Trade
    Last Post: 02-02-2010, 08:42 PM
  3. VY Series II Towbar Install
    By higgo23 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 16-12-2009, 08:05 AM
  4. vk towbar fit vl?? instructions on how to install?
    By chester2006 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 03-10-2006, 10:45 AM
