Hey guys I'm getting a fault code in my Vr Ss 5 speed code is 15 which is ect sensor voltage high I have replaced the sensor and plug to the sensor has done nothing still getting the light after 2 or 3 minutes after starting engine has anyone else had this problem or knew how to fix it ?????
code 15 is coolant temp sensor voltage high . if you have replaced the sensor you will need to clear the fault codes , by removing the " engine " fuse in the relay compartment , [ black plastic box thing ] near the battery. put fuse back in after a few minutes. if the same fault code keeps showing , could be a wiring [ loom ] problem.
