Results 1 to 8 of 8
Thread: More problems with my Ute :(
    VZ Custom 3.6L Alloytec, VS Ute 3.8L Ecotec
    Nov 2008
    Darwin
    Default More problems with my Ute :(
    ok so i fixed my last problem which turned out to be someone decided to pour something into my fuel tank. i cleaned and flushed out the fuel system (Tank, Lines, Rails and Injectors). was running good for a little bit but now i have another issue. while im just cruising along i lose all acceleration but if i let the peddle off a bit it works again but stops working shortly after and keeps doing it each time i drop back on the peddle. its kinda like from full throttle down its slowly draining. if i turn the car off and go again it works good for about 500m then starts draining again. its a 1997 VS V6 Manual Ute
    Nov 2008
    Darwin
    i realise that prob doesnt make much sense. its really hard to explain. but i hope someone can understand it
    kcpwns's Avatar
    kcpwns is offline Kicker - Livin' Loud :)
    VY V6 Equipe
    Jan 2010
    Shepparton
    It isn't get enough fuel, air or spark...I'm guessing fuel replace your fuel filter. Check to see if your injectors are working properly and also check your fuel pressure regulator.
    I'm not 100% sure but that may be causing a problem as your tank was tainted.
    Also check you spark plugs and leads just encase
    Quote Originally Posted by some_guy View Post
    This posts stupidity makes baby jesus cry.
    My Ride
    currently retrofitting projector headlights
    Nov 2008
    Darwin
    air is good, all spark components are brand new, i took the fuel line off the rail and turned it on and there is a good flow so i know there is fuel getting there
    kcpwns's Avatar
    VY V6 Equipe
    Jan 2010
    Shepparton
    I dunno mate I'm not really a mechanic. I just know from prior experience...mite have to take her to a mechanic? Specially if someone has poured shit into your tank
    My Ride
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    Quote Originally Posted by jwaye2 View Post
    Sounds like your pump pressure is low.. and the pump itself is lubricated by fuel, so if someone poured water or something in, its probably seizing slowly. Sure you turned the pump on and fuel came out at idle revs, that doesn't mean you're getting good pressure at speed or under load now does it? fuel coming out the rail only means your pump is working, not working well.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    VS 96 Exec Wagon
    Jul 2009
    Queensland
    Defiantly, change the pump and filter.. When you have done that, it wouldn't hurt to put some Injector cleaner in there.. (If you want too that is.)
    But as Vee-Ard said, I'd be defiantly checking into the Fuel pump .. Suppose you wouldn't happen to know what got in there?
    Paintball.. It's not just a Sport.. It's a lifestyle!
    Check out my VS Wagon !
    See my Re-Mixes here YouTube - Dtek5
    Manual Vs V8 Stato
    Dec 2009
    I had EXACTLY the same issue mate, ended up replacing Fuel pump, filter, TANK, cleaning out all the fuel lines with carby cleaner or replace them either way they're going to need to be clean also clean the injectors. Really I'd be replacing it all to know its done right.
  1. Signal Problems Aand LPG Problems
    By reyyan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-03-2011, 08:33 AM
  2. VZ SS random problems starting and also lock problems.
    By alista in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-12-2010, 11:23 PM
  3. Id like to know common problems with air con in vt so i can diagnose my problems
    By dope505069 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-02-2010, 03:21 PM
  4. ignition problems or starting problems
    By Vs-AclaimII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 04:55 PM
  5. Problems with Air-con
    By Degeko in forum VY Holden Commodore (2002 - 2004)
    Last Post: 06-03-2006, 09:27 PM
