Results 1 to 11 of 11
Thread: 40L60E trans probs...
    VS S-Pack SII
    May 2008
    Default 40L60E trans probs...
    The trans i have is a "6HDD".
    When i first start the car in the morning, it may (most times) slip while in first gear, then once i nurse it (very soft throttle till fast enough for 2nd gear) and let off the throttle, it clicks nicely into 2nd, then it's ok.
    BUT... before you say my first gear is stuffed... this only happens first thing in the morning... After that, the whole trans works like normal. (every gear, up and down)
    The fluid level is fine & The fluid colour is good.
    To me, it's kinda like when i start up in the morning first thing, the Torque convertor is not getting enough fluid/pressure, like it's got blocked supply lines or something, but then comes good once it's filled up??? (I believe the Toque convertor is full of fluid all the time, unless the car is not running for a while, say overnight, in which "some" fluid can drain out, back into the sump, which will get pumped back in on startup)
    Could this be a faulty PCS (Pressure control Solenoid)??
    My understanding is, too HIGH a pressure = hard shifting (Corvette servo??) and too LOW a pressure = very soft/slip shifting. So i could have a PCS that is sluggish when the fluid is cold, but "frees up" when the fluid warms up?
    Any other input would be great? if im not on the right track, could it be any other electric input? 1-2 shift solenoid? Pressure switch assy? TCC?
    thanks in advance.
    Oh, and i found this:
    transmission-slipping-sluggish-start-up
    And yes, i have an aftermarket cooler mounted at the front of the car....
    EDIT: No codes come up when i join the pins on the diagnostic plug under the dash.
    zapper-l67's Avatar
    zapper-l67 is offline LS# Eat One Today...
    VX Calais
    Jan 2010
    Western Vic
    4l60e Problems and Solutions
    I found this on another forum, thought it might helpful seeing as so may of us have trans
    problems i'm no trans prerson so i'm sorry for any inaccuracies.
    hope it helps at least one person out if not ohwell
    Common failures on 4L60E, symptom -> cause -> any possible repair:
    1. Slow, slipping or no reverse: “lo-reverse” clutches are worn out, fluid leak in the
    reverse apply circuit, or broken sunshell. It is possible to remedy a fluid problem by
    removing the checkball from its cage in the case in the rear of the trans may help (must
    remove valvebody), or adding a high-viscosity additive such as Lucas Transmission
    additive or other seal restorer product. May also have worn boost valve (can replace in
    the pan).
    2. 1-2 shift does not happen at WOT until you let off the gas: Best case: try
    replacing the TPS. Middle case: leak in the 2nd gear apply circuit (servo assembly or 1-2
    accumulator). Doublecheck by using the pressure gauge and watch for a big drop when
    the PCM commands 2nd gear. Worst case: poor line pressure rise (see below).
    3. 1-2 Shift shudder at WOT; delayed or abnormal 1-2 shift; There's a problem
    ONLY on the 1-2 shift: 1-2 accumulator piston cracked or stuck cocked in the bore. Check
    the yellow spring inside the accum housing for breakage. Also, if the accumulator housing
    walls are scored, the housing must be replaced. Easy fix in the pan.
    4. 1-2 shift is delayed and harsh, may not shift into OD: Check TPS for smooth and
    linear electrical response over the entire range of motion. If not, replace.
    5. Trans does not upshift out of first, speedometer reads zero at all times: VSS
    failure. Easy fix on rear of transmission, but xmember must come out to access VSS.
    6. No 3rd or 4th gear: “3-4” clutches are worn out. R&R. The car is safe to drive
    (in 2) until you can get it fixed.
    7. Sudden grinding noise with no prior warning primarily in 2nd gear, behavior in
    reverse may be abnormal; sunshell is fractured. R&R. Try not to run or drive the car or
    further damage could result.
    8. 1st and 3rd only, no 2,4 or R; sunshell is fractured or splines are sheared off.
    R&R. Try not to run or drive the car or further damage could result.
    9. No 2nd or 4th gear. 2-4 band is slipping. Servo seals may be damaged (can be
    fixed without removing trans. Otherwise, 2-4 band is worn out. R&R.
    10. Trans shifts into gear harshly, 3rd gear starts, manual 2nd available but no 1st,
    no 4th, and no TCC lockup: No power to transmission, or trans is in limp-home mode.
    Check trans fuse underhood, and make sure transmission electrical connector is plugged
    in. Easy fix.
    11. No 1st or 4th available; trans shifts 2nd to 3rd by itself in D or OD : ShiftA
    solenoid failed. Easy fix in the pan. Or a wiring problem from PCM to trans.. or PCM.
    12. No 2nd or 3rd available: ShiftB solenoid failed: Easy fix in the pan. Or a wiring
    13. No TCC lockup: Brake pedal switches improperly adjusted (always on), TCC
    solenoid failed (easy fix in the pan), TCC clutch worn out (must remove trans and replace
    TC).
    14. TCC always locked: TCC apply solenoid circuit shorted to ground, TCC solenoid
    blockage (easy fix in pan), or TC broken (must remove trans and replace TC).
    15. Horrible noise in 4th and feels like the brakes are on: overrun clutches are
    applying due to a cracked or leaking forward piston. Overrun clutches will be worn out
    after 30 seconds of this behavior. Car can be safely driven in D. R&R.
    16. Soft shifting, gradual performance degradation: Poor line pressure rise due to
    leaking boost valve, clogged EPC filter screen, failing EPC solenoid, or worst case: leaky
    seals throughout. Transgo HD2-C kit fixes first two without removing trans. Seal restorer
    may fix last problem, but probably R&R. Also try a transmission flush with BG brand
    products (Firestone stocks it).
    17. No forward movement in OD or D, but L2, L1 and R work: Forward sprag is
    broken. R&R. Try not to run or drive the car or further damage could result.
    18. Extremely harsh shifts from P or N, normal shifts at WOT: EPC (Electronic
    Pressure Control) solenoid failed. Easy fix in pan. Fix as soon as possible or hard parts
    will eventually break.
    19. Loud bang, grinding sound, loss of all gears, and a binding driveshaft: snapped
    output shaft. Try to wiggle driveshaft - if more than 0.020" play, that's the sign. R&R.
    20. Trans seems noisy when moving in 1st and Reverse, noise goes away instantly
    if you shift to N or the trans goes into 3rd gear: Reaction planetary is worn out due to
    high miles or insufficient lubrication. Not a critical failure, but not a good sign either. R&R
    sooner rather than later.
    21. No movement in any gear: pump failure, or total loss of fluid. R&R, or refill pan
    and find the leak. If out of fluid, avoid running the engine until the trans is refilled to avoid
    pump damage. To check for pump failure, check fluid level with the engine off, then start
    the engine and recheck fluid level. If level does not go down when engine is running, the
    pump is broken.
    22. Transmission does not shift automatically, only manually. Swap in a
    known-good PCM, check wiring, check other sensors such as VSS and TPS.
    23. 3rd gear starts, can manually shift through all gears. When car has been
    turned off for a bit, then back on it will run normally.: VSS dropoff w/ Hi-stall converter.
    The rpms are too high, but VSS is showing no movement. Happens after a tire burning
    take-off. Doesn't store a code, will not throw a CEL (I've heard that it will store a code if it
    happens 3 or more times). Cure: Reprogram PCM for VSS dropoff -- PCMforLess knows
    about it.
    24. Car feels sluggish off the line, No 1st, 4th or TCC lockup available, Manual 2nd,
    3rd and Reverse are only available gears, CEL is on: Transmision is either in limp-home
    mode or has lost electrical power. If there are lots of error codes in the PCM, check the
    underhood fuse that powers the transmission, and if it pops again, look for a short in that
    circuit like an O2 sensor harness touching exhaust. Otherwise, check PCM codes for a
    particular fault in the transmission causing the PCM to put it in limp-home mode.
    25. Fluid leak out of the front of trans where the converter connects; partial or full
    loss of movement: Front pump bushing walked out. R&R. May have to replace converter
    also if hub is scored. Note that a leaking front seal usually means the bushing is walking
    out (i.e. call your local trans shop and schedule an appt.).
    26. Torque converter shudder in 4th while lockup is engaged; problem goes away
    when the brake pedal is pressed slightly to unlock converter. Have a shop verify line
    pressure, and provided no valves in the TCC hydraulic circuit are worn, replace the torque
    converter. Also, Lubegard Shudder Fix will at least fix this for awhile. Or try a
    transmission flush by a shop that uses BG brand products.
    27. Shift suddenly become very hard. When going from park to either reverse or drive
    it slams into gear. 1-2 and 2-3 shifts are also harsh. All gears seems to work. Problem
    may be intermittent: Check TPS for smooth electrical response. If the response is jumpy
    or erratic at all, replace TPS.
    28. All fluid pumped out through the vent tube: Plugged cooler line. Flush the
    transmission cooler and cooler lines. Also could be overfiled transmission.
    29. Car acts like it's in OD in neutral, car is locked stationary in R, engine feels
    loaded in P, all four forward positions work fine:Internal crossleak feeding the forward
    clutches all the time. Most likely a cracked input housing. R&R required. Car can safely be
    driven gently in forward gears until the repair.
    30. Needle bearings in the pan, first gear and/or reverse may be noisy: Either a
    torrington bearing or a planetary bearing is on its way out. Trans will eventually die a
    loud, catastrophic death. Cheaper to rebuild now (saves further damage to hard parts),
    but requires R&R. It is drivable until it breaks.
    31. 1-2 or 2-3 shift is slow/soft above part throttle: Trans is on its way out. R&R.
    Operational phases
    A torque converter has three stages of operation:
    * Stall. The prime mover is applying power to the pump but the turbine cannot rotate. For example, in an automobile, this stage of operation would occur when the driver has placed the transmission in gear but is preventing the vehicle from moving by continuing to apply the brakes. At stall, the torque converter can produce maximum torque multiplication if sufficient input power is applied (the resulting multiplication is called the stall ratio). The stall phase actually lasts for a brief period when the load (e.g., vehicle) initially starts to move, as there will be a very large difference between pump and turbine speed.
    * Acceleration. The load is accelerating but there still is a relatively large difference between pump and turbine speed. Under this condition, the converter will produce torque multiplication that is less than what could be achieved under stall conditions. The amount of multiplication will depend upon the actual difference between pump and turbine speed, as well as various other design factors.
    * Coupling. The turbine has reached approximately 90 percent of the speed of the pump. Torque multiplication has essentially ceased and the torque converter is behaving in a manner similar to a plain fluid coupling. In modern automotive applications, it is usually at this stage of operation where the lock-up clutch is applied, a procedure that tends to improve fuel efficiency.
    The key to the torque converter's ability to multiply torque lies in the stator. In the classic fluid coupling design, periods of high slippage cause the fluid flow returning from the turbine to the pump to oppose the direction of pump rotation, leading to a significant loss of efficiency and the generation of considerable waste heat. Under the same condition in a torque converter, the returning fluid will be redirected by the stator so that it aids the rotation of the pump, instead of impeding it. The result is that much of the energy in the returning fluid is recovered and added to the energy being applied to the pump by the prime mover. This action causes a substantial increase in the mass of fluid being directed to the turbine, producing an increase in output torque. Since the returning fluid is initially traveling in a direction opposite to pump rotation, the stator will likewise attempt to counter-rotate as it forces the fluid to change direction, an effect that is prevented by the one-way stator clutch.
    Unlike the radially straight blades used in a plain fluid coupling, a torque converter's turbine and stator use angled and curved blades. The blade shape of the stator is what alters the path of the fluid, forcing it to coincide with the pump rotation. The matching curve of the turbine blades helps to correctly direct the returning fluid to the stator so the latter can do its job. The shape of the blades is important as minor variations can result in significant changes to the converter's performance.
    During the stall and acceleration phases, in which torque multiplication occurs, the stator remains stationary due to the action of its one-way clutch. However, as the torque converter approaches the coupling phase, the energy and volume of the fluid returning from the turbine will gradually decrease, causing pressure on the stator to likewise decrease. Once in the coupling phase, the returning fluid will reverse direction and now rotate in the direction of the pump and turbine, an effect which will attempt to forward-rotate the stator. At this point, the stator clutch will release and the pump, turbine and stator will all (more or less) turn as a unit.
    Unavoidably, some of the fluid's kinetic energy will be lost due to friction and turbulence, causing the converter to generate waste heat (dissipated in many applications by water cooling). This effect, often referred to as pumping loss, will be most pronounced at or near stall conditions. In modern designs, the blade geometry minimizes oil velocity at low pump speeds, which allows the turbine to be stalled for long periods with little danger of overheating.
    Torque converter - Wikipedia, the free encyclopedia
    This is the sort of stuff that happens when the kids get into Dads tool box over weekend.
    Money will be spent, Dreams will be shattered, Lessons will be learned, and a wealth of information will be gained.
    VS Berlina soon to be 5L
    Aug 2010
    Girrawheen
    solonoids are buggers some times they only play up when hot, my box use to thump into drive, changed pcs and all good now. so might be worth a try, and i thought these boxes couldnt drain back but could be the problem, worth a go mate
    VS S-Pack SII
    May 2008
    Quote Originally Posted by Jacko84 View Post
    Yeah, my transmission goes into and out of gear smoothly when you flick it in and out of drive, and in a timely manner... no delays when you go from N to D.
    I'm thinking it's a blocked filter or something????
    VY Executive S2/ VY SS 6sp
    Jan 2011
    Western Australia
    i think it is more likely a blocked filter or your oil it to thick in the morning change the filter and oil and see how it gose
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Worn low/reverse clutch - it's the one that slips and wears first as it takes the most load. Proper fix is an overhaul, but a temporary fix (maybe 12 months) is to add a can of "trans stop slip"...buy a better brand - there are a few brands available. It will make the clutches grip better and reduce the slip. If left alone the slip will get worse. Cost is under $20. Otherwise it's $2000.
    VS S-Pack SII
    May 2008
    Quote Originally Posted by hako View Post
    Yep, but wouldn't it always slip in first if that was the case?? not just when it's first started up in the morning?
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    Quote Originally Posted by PanthaVS View Post
    Mine is slipping when cold at times as well. But when I know it slipping I put it into neutral then back into drive which seems to fix it. If I do not do that the trans fluid seems to come out of the dipstick...
    My trans fluid is brown (which could be a bad thing) It should be dark red.
    TrikkBen's Avatar
    TrikkBen is offline Compulsive.
    BNR32
    Apr 2009
    SE, Vic
    Could be the seals internally, When cold they contract, leaking fluid past, until they heat up, expand and seal up again.
    There is no such thing as stupid questions, Only stupid people.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    This could be due to seals etc being hard when cold (as TrikkiBen says), then soften and seal better....also clutch packs may swell slightly and grip better when they warm up.
    No matter what, you've only got $15 on a can of "Stop Slip" to lose....and that's hard to argue about.
    VS S-Pack SII
    May 2008
    UPDATE:
    Found this:
    Automatic Transmission Repair and Replace
    Quote Originally Posted by website listed above
    Another problem that affects the operation of the torque converter is a condition called "transmission drainback." One-way check valves normally keep the torque converter full of fluid when the engine is shut off. But if the transmission input shaft bushings are worn, it can create a path for fluid to drain out of the converter back into the transmission. The loss of fluid from the torque converter can make the transmission feel as if it is slipping on initial take-off for about five to 10 seconds
    How hard/eay is it to check and change the input shaft bushings?
  1. vq 5L trans probs
    By thomas86 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-11-2009, 09:10 PM
  2. trans probs
    By teote1 in forum Just Commodores Polls
    Last Post: 26-02-2009, 02:09 AM
  3. V8 trans probs
    By undar8ed1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-12-2008, 02:50 PM
  4. VS II V6 Missing and trans cooler probs
    By nick88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-01-2007, 06:42 PM
  5. vr trans (not the standard probs but, i need help)
    By WILD VR CLUBBY in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-10-2006, 10:29 PM
