I installed my towbar yesterday and everything is sweet, but i have 2 extra bars that are to support the boot apparently. I just have know idea where these 2 bars go, can anyone help me out?
Not sure if this is what you're talking about, but on some of the heavy duty setups i've seen they use additional bracing from the top shock absorber mount in the boot back to the floor.
Z' Series HSV 297KW 6lt LS2 Conversion For Sale!PM Me For Details
Depending on the brand, they go diagnally form the boot floor towards the rear forwards and upwards towards the parcel shelf. Wxactly where they attach to differs with each brand of towbar, but the mounting points should have been outlined in the fitting instructions.
ok the towbar is a hayman reese 1200kg if that helps
The hayman reese should be mounted to the chassis rails of the car not the boot,they are a one piece bar with a tongue on either side with 2 holes for the bolts,how big are the other 2 bars?
The boot support struts go inside the boot. Although you don't need them for the 1200kg bar, only the 2100kg bar.
So the boot wont warp when i tow the tinnie or motorbike
No so the boot wont fall off
The reason for the boot supports is to stop the car from kinking at the back doors. It doesn't happen as long as you don't go over the 1200kg limit without the boot supports.
