Results 1 to 24 of 24
Like Tree8Likes
  • 1 Post By wraith
  • 4 Post By RX25SE
  • 2 Post By HamaTime™
  • 1 Post By Nobody Actually
Thread: welded diffs
    vs commodore
    Jan 2009
    Default welded diffs
    just wondering is it wise to reweld a diff that the welds broke on or just a new diff and weld it as thinking of welding both diffs its for a burnout car not street use
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    stuntmanmike's Avatar
    stuntmanmike is offline Car wotsit & stuff
    VP 3.8 V6 Auto and VS BT1 5.0
    Jun 2009
    At home on planet earth...
    Welding anything will generally weaken the parent material. If the welds have failed then it will be more likely to fail again. IMO a welded diff is a poor man's locker diff. If you can spare the expense for a spool or good LSD then that could be the way to go.
    It won't hurt to try welding the diff up again if that is what you are keen on doing.
    If you can: Clean the surfaces with solvent, air dry for a suitable period of time (so you don't catch on fire or burn your garage down) and heat up the area where you will be welding with an oxy torch so that it heats up to a "dull red" and then weld onto that glowing surface. Lay down a strong weld run into the heated area using low hydrogen rods that are dry (drying rods in a oven for 15 minutes on allow temperature will pull any moisture out of the rods). MIG or TIG won't have this problem if you are using Argon as the shielding gas.
    Put the heat back on the weld when you have completed the weld run and allow the welded areas to cool down slowly. Quench with oil when the welds cool down below the "dull red" colour. Submerse the parts in oil for an hour if you can. Water is no good here. Quenching the welds with water will result in brittle welds that will be prone to cracking.
    It will be far easier to get a second hand "open diff" center and convert that to a locker with a mini-spool or full spool hat. Good luck with it and enjoy!
    vs commodore
    Jan 2009
    would go minispool if had more time need it done this saturday as we just got the car back to the house then and wraith the black vs lives again lol and we arent welding it ourselves my cousin who is a boiley who knows what he is doing is doing it for us
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    Whoa no way :P Just weld it see what happens it's only a skid pig.
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    Wow. whats all this welding tips shit? just fill the goddamn centre with beads and you cant go wrong.. You're already being cheap about it, what does it matter?
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    This is pretty strong.
    (bit hard on clutches though)
    woteva's Avatar
    woteva is offline NEED 4 SPEED
    VRII V6 Auto Wagon
    Jul 2005
    Adelaide S.A.
    Would be a bit hard to spin the wheels with that ^^^
    http://woteva.tk/
    If it ain't broke... I can break it for you
    RX25SE's Avatar
    vsII acclaim wagon
    Jan 2009
    Nah. Spins that no probs.
    I have a pod filter and LEDs so I estimate my V6 now has 300Kw ATW.
    woteva's Avatar
    VRII V6 Auto Wagon
    Jul 2005
    Adelaide S.A.
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    BW78 diffs are bloody hard to get weld into you have to weld it with the centre pulled in half and that only gets one side welded the second side you have to weld through a half inch hole in the centre and is not fun LOL
    HamaTime™'s Avatar
    HamaTime™ is online now VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    Buy a locker and do it properly...
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
    vs commodore
    Jan 2009
    well re welded the diff that the welds broke on working well so far just by turning it around in the back yard will be put the the test next sunday out at the burnout comps
    vs commodore
    Jan 2009
    well the car is coming back home the diff broke again first run on sunday
  15. #15
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
  16. #16
    Nobody Actually's Avatar
    Nobody Actually is offline luxo barge
    VS s2 Caprice 5l = slow
    Aug 2005
    Queensland
    Quote Originally Posted by james90vs View Post
    FFS buy the spool
  17. #17
    VS V8 Manual
    Jun 2011
    NZ
  18. #18
    vs commodore
    Jan 2009
    its not my car so i dont car he has another two diffs sitting behind the shed ready to be done
  19. #19
    VS S-Pack SII
    May 2008
    its not my car so i dont care he has another two diffs sitting behind the shed ready to be done
    Not diggin at ya or anything... but if you don't care... why are you asking for advice?
  20. #20
    VS V8 Manual
    Jun 2011
    NZ
    likes to "read his on voice" perhaps haha
    VS V8 Manual ... Reppn it for NZ
  21. #21
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    spool is cheap and a lot more reliable, just tell him to do it. Any average mechanic could install on in a open center in the same time it takes to weld a center, clean it out etc.
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
  22. #22
    vs commodore
    Jan 2009
    because we were both curious and i think if he keeps breaking welds as last one they couldnt actually open the centre right up as the one in it was bashed out big time so thought it wasnt going to last but stayed locked the hole time
  23. #23
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    Do it right and get a spool ffs James stop doing shit half assed.
  24. #24
    vs commodore
    Jan 2009
    hey i did stop doing shit half assed i brought a new car lol and tell carl that not me
  1. welded flywheel and ring bedding.
    By nalchlan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-06-2011, 10:52 PM
  2. VP Welded Diff
    By Tuff-VP-Wagzz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-12-2010, 06:04 PM
  3. welded diff broken
    By MX_Leigh in forum General
    Last Post: 01-04-2010, 04:20 PM
  4. Welded Diff
    By DAMO_5L in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-08-2006, 02:44 PM
  5. Welded up back Exhaust System
    By Stewart1000 in forum General
    Last Post: 05-03-2006, 01:40 PM
