Results 1 to 4 of 4
Thread: Replacing a WINDING window
    VR Executive Commodore
    Jul 2011
    SA
    Default Replacing a WINDING window
    Hi guys,
    Recently some mother effer randomly smashed my drivers window in.
    I've bought myself a new one and gave it a shot at replacing it but i've run into a brick all and there is knacker all help out there for VR's with winding windows. It seems the whole forum world only cares about electric windows.
    I've taken ALL the door trim off but that still dosent give me access to the winder. To do so i need to separate the door but it's all pressed metal. How the hell am I meant to get into there to change it??
    Someone please help! It's winter where i live... driving without a window is bloody cold.
    Cheers,
    Jhock
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    The winder should not need to be removed?
    First I would make sure all the broken glass is removed... Never had to this on a Vr. Anyway on some doors there is bolt on the side that loosens the window guide rail?
    I think the trim on the outside that keeps crap from going in the door also needs to be removed.
    Also at the bottom of the window that attaches to the regulator (winder) there is a screw/bolt at each end that needs to be undone. The window needs to be wound down to a point where you can see these screws/bolts through the gaps on the door.
    I am not sure this will help, but at least I gave it a shot.
    Hangman's Avatar
    Hangman is offline Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    Sorry mate, but if you've taken all the door trim off, that's all the access you get.
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
    Vr ss & vy v6 wagon
    Jan 2010
    Central Coast, NSW
    the winder mechanism shouldnt need changing,just the window.
    to put the window in,i cant remember exactly how it goes but i do remember the window had to go on an angle.
    the bottom pointy bit of the window that aims towards the front of the car had to go in first aiming towards the ground and then it sort of went from there...
  1. Window gets stuck when winding up!
    By cameroony in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-07-2011, 10:37 PM
  2. Replacing VY Single window with Triple window cluster............!!!
    By frontier in forum VY Holden Commodore (2002 - 2004)
    Last Post: 08-06-2010, 01:30 PM
  3. window scratches made while winding window
    By callum_88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-07-2009, 08:30 PM
  4. removing/replacing window winding mechanism?
    By Victimiza in forum General
    Last Post: 21-02-2008, 11:08 PM
  5. VS Acclaim - Window Winding Issue
    By hightekhosting in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-09-2007, 01:52 AM
Tags for this Thread
