Results 1 to 5 of 5
Thread: urgent help needed with installing front seats 94 vr
    Calais V6 3.8
    Mar 2009
    Default urgent help needed with installing front seats 94 vr
    i have just replaced my bucket seats for some standard seats out of a vn passanger bolted on straight as good fit no hassles. put the drives seat in and whattaa ya get its on a lean everything is bolted in properly even tried fitting the side its leaning on with spacers removed pulled rails back flush both sides tried everything. looking from the front of the car it is leaning to the right (towards the passanger) not heaps but enough to notice. oh and forgot to menchin adjust the seat is slightly more difficult like its seized, fine when out. please someone help driving me insane.
    1994 vr commodore hsv body 17'' powdercoated rims, lowered on superlows, tinted, sounds, black topped. turbo project in the making.
    Calais V6 3.8
    Mar 2009
    somone must no
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    This is very common for vn-vs seats to lean inwards. What will help alot of this (drivers seat) is to reshape the front left mounting point. This is supposed to be a bit of an s shape with a distincrive step down, but overtime and carrying heavy people etc this tends to flatten out, hence lowering it and the inwards lean.
    You need to reshape this bracket. Also check if the floor pan has sagged or cracked near the mounting point.
    Z' Series HSV 297KW 6lt LS2 Conversion For Sale!
    PM Me For Details
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    It's normally the passengers side that bends up the most often. --->>> http://forums.justcommodores.com.au/...to-middle.html
    As for your drivers seat I would say the bottom frame is bent for sure. Take seat out and CRC all the sliders and clean the rails out.
    Is the seat flexing on the upright part? If you sit in the back seat and put a hand on each side at the top, can you flex it forward and back? If yes the side mounting allan screws are loose.
    Also when fitting dont do any of the bolts up too tight before you have all 4 in. Just a 1/4 turn less then firm. The seat should still slide over the bolts and see if the rails still jam up.
    and 3 Dangerous non ABS VN's
    Calais V6 3.8
    Mar 2009
    i didnt do them up as tight as i could and yeah it low key flexs i would say its bent, its the back left corner rail thats bent i think (from looking in the back seat) i put threee spaces inbetween and now when adjusting the seat it isnt so jammed up but still looks like its on a lean you can pull it up and down and see how bent it is probably could do with a nother 1 or two spacers to stop it from leaning and a longer bolt. is this safe to do if not do i have to bend it back? thanks
  1. Vt calais international front seats needed!
    By adem1989 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-12-2010, 07:22 PM
  2. Front seats needed urgently
    By JODYANDBENNY in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-10-2010, 08:07 AM
  3. Help Needed with Changing over VT front seats
    By 5LVT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-06-2010, 06:04 PM
  4. Urgent Help! Installing New Link Pin
    By sweefu in forum General
    Last Post: 04-06-2009, 07:32 PM
  5. Installing front splits urgent help please
    By Spyper in forum Car Audio
    Last Post: 05-06-2006, 11:51 AM
