hey dudes just wondering if anyone can tell me what vac lines have to be hooked up for proper operation and if rocket cover breather have to be hooked up to the throttle body only because i have polished cover with no breathers . i have put it all on and its running like shit. any help would be appreciated
i run a active twin throttle and there arnt many vacume hoses on my vn just a couple idle air controle which is at the front of one of the throttle bodys,map sensor,fuel pressure regulator and one more that not sure about which attach under the throttle bodys which had brass attachments for the hoses that were taped into it and on back brake vacume as for the breathers i run heater hose to a T peice and same hose to the back of engine and only run PCV valve for rego if there all hooked up maybe look at another problem.
thanks mate could you send sume pics of the top hat i have 2 vacume lines in the top hat one gos to brake vacume and the ather gos to the littel black box on the right hand side of the fire wall .is this the map sensor.i think my problem mite be the fuel pressure fegulator theres no vac hooked up and is there eney sensors hooked up to the manifald i only have the 2 on one of the throttle body
