hey guy i am sure there is a tread on here about this and i cant find it. so i was wondering if anyone can tell me or show me an how to.... on removing the front door?
thanks
There is a tool like a dent puller not sure what the name is. which you put through the hinge where the pin is and screw the bigger part on the end. which has to be the same size as the pin
that is in the hinge....
Then pull upwards until the pin comes out...
commodore door pin remover is what you need with plenty of wd40.
yu i had to by one $15 at you can yous moltygrips and a hammer 3 of the 4 door cume i had to go and get the tool for the larest
You cna buy a tool or you can do it with a screwdriver, punch and a hammer + pliers..
Both methods seem to work well.
aZk.
