Results 1 to 5 of 5
Thread: VR V8 Strut Brace Installation and questions
    Rusty's Avatar
    Rusty is offline ٩(-̮̮̃•̃)۶
    304 Ute, WRX Impreza
    Mar 2010
    Queensland
    Default VR V8 Strut Brace Installation and questions
    Hi Guys,
    Been searching for a while and cannot find info on how to install a front strut brace on a VR V8 Commodore. Can someone who has done it please shed some light? It is a standard whiteline brace and I pick it up monday.
    I was also wondering whether the addition of a front strut brace without stiffening / strengthening the rear will have any bad effects?
    Thanks for any info guys
    VS UTE, HT MONARO REBUILD
    Dec 2010
    mate after reading a few threads i have found that a strut brace will not do much in the way of increase handling and such as the shock towers on the commodores are fairly sturdy, you probably will get a bit of an improvement but it's not a bolt on and do wonders type of thing. as for the brace instillation i would have thought that it would come with some kind of instructions for installation, is it new or second hand, if its new more than likely it will have instructions if it's second hand then might have to get them off the net or some of the guys on this forum, hopefully i've shed some light on your question.
    Rusty's Avatar
    Mar 2010
    Queensland
    Quote Originally Posted by Shooter 88 View Post
    Hey mate, cheers for the info. It is new so here's hoping it comes with instructions.
    Not worried about improvements as such but am concerned about negative affects to other areas if any. The reason i am getting it is to preserve the strut towers as they have some cracks appearing from being on SSL and the weight of the v8 etc. The cracks are common from HQ on wards appearantly.
    Cheers mate
    Dec 2010
    fair enuff mate, i would also be installing a strut brace if my towers were cracked, i have also heard that is common for them to crack, youd recon holden would have fixed the problem by the time they got the the vs, anyways i don't think that putting the brace is gonna badly effect any other area's maybe just check all the bushes on the front end, if any look cracked or worn out then it could be best to replace them so you get a nice solid and safe front end.
    Rusty's Avatar
    Mar 2010
    Queensland
    Hey guys, cheers again for the info.
    Strut Brace finally arrived from whiteline - installation a peace of cake. Undo a couple of bolts and whack it in, no dropping of the struts or anything! No instructions unfortunately but was straight forward.
    Haven't taken it for a drive but am not expected a noticeable difference in anything at this stage. Here's hoping that it preserves the towers until I get them re enforced.
  1. vs strut brace
    By vs-v8-ute in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-06-2011, 11:46 PM
  2. [SA] Strut brace
    By mick_VTSS in forum Parts And Other Items For Sale
    Last Post: 23-09-2010, 08:21 PM
  3. strut brace
    By vz 914 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 29-09-2008, 07:25 AM
  4. VT Strut Brace
    By gonz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-09-2006, 07:43 PM
  5. does a strut brace help a VL?
    By Pistol in forum VL Holden Commodore (1986 - 1988)
    Last Post: 04-10-2005, 10:20 AM
