Results 1 to 8 of 8
Thread: Suspension knock on braking
    VS SS
    Aug 2010
    ACT
    Default Suspension knock on braking
    Hey guys, seeing as the search wasn't really helpful, my problem *seems* to be that when I brake or occasionally go up my gutter for my driveway I think the K frame hits the steering rack on the passenger side, as to which part is doing the moving I'm unsure, also I can see marks on the steering rack opposite part of an off hanging bit of the K frame which has about an inch between them. My question is if it is this, what could be causing the problem? I've got work off tomorrow so I'll put it up on jacks and start searching but I'm not sure where to start, I'll check the K frame bolts are tight but other than that I don't know where else to look.
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Check caster bushes. Each end of the caster (Z) bar.
    Darcon666's Avatar
    Darcon666 is offline Evil is always around you
    The Wife
    Jun 2010
    At home
    As said by RX25SE... Radius/Caster bushes & ZBar.
    But also check you Link pins on the sway bar & your strut tops, See Here...
    Good luck.
    VS SS
    Aug 2010
    ACT
    VS SS
    Aug 2010
    ACT
    Got Under couldn't see much, most bushes were pretty good if a little old but the ones on the sway bar link *I think* looked pretty new, Is it supposed to only have 1 bush each side of the sway bar ring, it almost looked like it should have one on/inside the ring. Strut bush was fine. The bush on the front of the sway bar was the only one that had visual cracks but I don't know whether or not it would be causing the noise, K frame and rack bolts seemed tight. Anything I'm Missing?
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    It is most likely the bushes and bearings in you're Strut tower as these seem to wear out and the casing around the ball bearings crack and break as they are only plastic.
    If it's not a Symptom its not relevant, and if its not relevant I don't care!
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    Absolutely your sway bar link bushes mate, that will cause exactly the sound you are hearing, and yes there are meant to be bushes either side of where the thread goes thru the swaybar
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    You All ARE Wrong About A Commodore Being A 4 Stroke Engine... Or Any Car For A Matter Of Fact...
    A V6 CAN'T Run On ONLY 1 Cylinder... IT'S A 24 STROKE ENGINE... 4 CYCLES Per Cylinder... "Basically Three V-Twins Together
    VS SS
    Aug 2010
    ACT
    Cool thanks guys, I'll get a photo up of the link in the next few days because I couldn't see anything wrong but I know sweet FA about bushes etc.
  1. squeaking/creaking noise from suspension when braking!!
    By mike4226 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 16-03-2011, 08:28 PM
  2. Front Suspension Knock
    By clintonhadenham in forum VL Holden Commodore (1986 - 1988)
    Last Post: 05-08-2010, 08:01 AM
  3. knock sound when braking
    By georgeonboost in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-11-2009, 09:45 AM
  4. Suspension Knock
    By PinkFloyd in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 16-06-2009, 06:31 PM
  5. Front Suspension Knock/Thud
    By Demons1964 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-05-2005, 10:09 AM
