Hi I Have A Problem With The TPS Sensor In A Holden Commodore Could This Problem Cause It To Be Hard To Change From P to D And A Clunk When Goin Into Drive.... The Car Also At Times Tends To Have A High Idle At Start Up.... I Had Run A CHeck On The Codes Of The Car And Came Up With 19 And 22 Any Help Regarding This Would Be Fantastic
Search button.....
or you could just tell him to go get another one because the one he currently has is completely stuffed!
If it's not a Symptom its not relevant, and if its not relevant I don't care!
19, 21, 22 Is the TPS CIRCUIT or sensor.
