Results 1 to 2 of 2
Thread: V6 vs ute diff straight swap into V8 vs ute with lsd?
    VS ute
    Jun 2009
    Default V6 vs ute diff straight swap into V8 vs ute with lsd?
    g'day ive got a v8 manual vs ute with a lsd that needs recoing and i also have a v6 vs auto ute with an open wheeler diff in it, i was wondering if its a straight swap to put the v6 diff in the v8 ute to get it going again while i save for a reco, i plan on swapping the whole diff assemblies apart from calipers and rotors, am i going to have problems with the tailshaft, unis/yoke?
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Its a straight swap between vs v6 and v8 diffs. All the mounts/hangers etc are all the same for a ute. Only difference is the v8 has shot peened crown wheel and pinion gears to handle a little extra punishment. Also be aware that if they have a different ratio this will throw out your speedo accuracy (both should be 3.08:1 though).
    Basically drop your upper and lower control arms, panhard rod, tailshaft, shocks you can leave the calipers and lines attached by just opening op the tabs on the diff housing which holds the metal lines.
    Z' Series HSV 297KW 6lt LS2 Conversion For Sale!
    PM Me For Details
  1. [VIC] straight swap for series 2 flywheel (vic)
    By the executive in forum Swap / Wanted to Buy / Trade
    Last Post: 27-07-2009, 12:26 PM
  2. Will a Vy Diff be a straight swap into a Vt
    By damnet in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-05-2009, 08:48 PM
  3. LSD centre - straight swap?
    By maldotcom2 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-12-2008, 12:17 AM
  4. single spinner - LSD. straight swap?
    By =Calais v8= in forum V8 Development and Modification
    Last Post: 05-01-2008, 01:43 PM
Tags for this Thread
