Results 1 to 10 of 10
Thread: Vs wheel wobble
    vn vacationer auto v6 sedan
    Jan 2006
    Default Vs wheel wobble
    Hi , my Vs has of late developed a sort of wheel wobble that seems to be comming from front drivers side , i have put on new rubber , checked outer tie rod had discs machined and put new pads on , all to no avail , it seems a lot worse whenn turning right at slowish speed , almost like the wheel was buckled , whoop,whoop,whoop and the steering wheel vibrates in unison !, straight ahead not to bad though , any ideas ? , ta
    Cracka is offline Banned :P
    Old Sneakers
    Mar 2011
    Croydon
    hub assembly / bearing? just a guess though, could be a few things I suppose but that is what i'm sticking with for now.
    Quote Originally Posted by Julie View Post
    Just curious why a fella without kids wants to know what our kids eat... are you that dude in the dodgy free candy van?
    http://forums.justcommodores.com.au/signaturepics/sigpic83720_1.gif
    Wombles's Avatar
    Wombles is offline Cars cost too much.
    1995 VS Acclaim
    Oct 2009
    Check the bearing in the strut tower.
    http://forums.justcommodores.com.au/...e-acclaim.html
    My Commy
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.
    Discuss.
    Jan 2006
    Thanks for reply , when i jacked it up to check tie rods , there was no play , dummy i should have thought of bearing ! , ill give it a go tommorrow.
    Jan 2006
    To check strut tower , do i raise vehicle by jacking up under control arm?
    Wombles's Avatar
    1995 VS Acclaim
    Oct 2009
    I dunno how you'd check it in the car?
    Maybe just jack it and and see if there's any noises from it when you turn the wheel?
    My Commy
    Discuss.
    commodore
    Aug 2009
    australia
    your wheelnuts are tight arent they? just thought id ask, but id be thinking a buckled wheel i had the same problem recently, changed the wheel and problem solved mine was a back wheel and i thought the diff was going to fall out at least it felt like that.
    Hangman's Avatar
    Hangman is offline Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    ^Easy thing to check, stick a different wheel on it and see if it makes a difference.
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
    Jan 2006
    Hi ,just jacked up car again and no wheel bearing movement , lifted wheel up while car was one up and the strut bearing had some movement plate looked fine ,think its ok. Im wondering i put new rotors/pads in a week ago, cdould they be grabbing somewhat ? , that may explane why it mostly does it just before/after a corner
    Jan 2006
    Hi , have gone to hell and back trying to fix prob , apparently the discs my made gave me to replace old ones , have a millimeter smaller stub oppening that needs to be reamed out , didnt notice at the time but the discs didnt fitt in the stub properly ! , anybody come across this ?, cheers
  1. VX equipe wheel wobble
    By c2105026 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-05-2011, 11:28 PM
  2. Steering wheel wobble
    By OldDog in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-06-2010, 07:46 PM
  3. Wheel Wobble
    By boobotam in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 16-01-2010, 11:16 AM
  4. steering wheel wobble
    By VTPREDATOR in forum VY Holden Commodore (2002 - 2004)
    Last Post: 14-11-2008, 09:31 PM
  5. Front Wheel Wobble Car Shudder Help
    By jolea682 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 05-11-2006, 10:17 AM
