Results 1 to 9 of 9
Thread: Front of engine leaks coolant.
    Wombles's Avatar
    Wombles is offline Cars cost too much.
    1995 VS Acclaim
    Oct 2009
    Default Front of engine leaks coolant.
    Ok, so the front of me engine is leaking coolant. I have replaced the water pump gasket and it has not fixed it. Not to sure where it is coming from.. any ideas. Looks close to where the water pump bolts on..
    http://forums.justcommodores.com.au/...e-acclaim.html
    My Commy
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.
    Discuss.
    scvs6's Avatar
    scvs6 is offline Donating Member
    1995 Holden VS Berlina 3.8L Supercharged V6 L67
    May 2011
    Ballarat, VIC
    Maybe it's the water pump itself. It has a seal in it that can leak. You might have to change that and see what happens.
    Quote Originally Posted by Jasper44
    For all you kids out there, when your about to have sex, just remember that it would be better if you went out and shot a police officer with a bazooka instead.
    Including car parts (VS, VT, VX, VY, WH etc), my WH Statesman, and other things listed on eBay.
    Wombles's Avatar
    1995 VS Acclaim
    Oct 2009
    Opps.. Forgot to mention, I have changed it.. same time I did the gasket..
    Thinking that that was the problem..
    My Commy
    Discuss.
    Wombles's Avatar
    1995 VS Acclaim
    Oct 2009
    My Commy
    Discuss.
    Home built Charged VS Commodore
    Apr 2010
    New Zealand
    under the alternator but above the power steer pump is a steel pipe that goes thru the inside of the belt tensioner pulley, Thats your heater hose, Now on the motor end there is an O-ring that seals it, Replace that dont just check it and use a dab of oil for pushing it back in so you dont split or cut it..
    holden vs ute
    Aug 2011
    brisbane
    or its could be timing chain on side could be leaks or so! i have one atm gonna fix it as soon! only need new gutter!
    VS l67 statesman
    Dec 2008
    When I have to track down coolant leaks I use a white led spot light and park the car in dark place go over the motor the spot light really lights up any leaks even hair line fractures but you have to the green coolant for it to work
    Wombles's Avatar
    1995 VS Acclaim
    Oct 2009
    It looks like it's around the water pump area. but it's not that. Can only see it when your under the car.
    My Commy
    Discuss.
    vs commodore ute
    Jul 2011
    lakehaven
    maybe its just running down the pipes from further away from the waterpump making you think it is the water pump. maybe the heater valve they all seem to perrish after a while.
  1. Coolant leaks problem VZ SV6
    By Commy SV6 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 16-04-2011, 02:21 AM
  2. Coolant Leaks
    By Proman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-09-2010, 10:31 AM
  3. can incorrectly bleeding air from coolant cause leaks?
    By pillzor in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-05-2010, 10:14 PM
  4. VS Overheating - coolant leaks
    By HsvMan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-01-2005, 09:00 AM
  5. Coolant Leaks Into Interior
    By meh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-01-2004, 12:16 PM
