Results 1 to 6 of 6
Thread: vs air bag cover lifted on passenger side
    1989 vn white
    Jul 2011
    Warranwood, Melbourne
    Default vs air bag cover lifted on passenger side
    Also the airbag light is on the dash
    95 vs Calais
    Any ideas?
    Wombles's Avatar
    Wombles is offline Cars cost too much.
    1995 VS Acclaim
    Oct 2009
    Lifted as in how far?
    Go to your mechanic to check the air bag fault.
    http://forums.justcommodores.com.au/...e-acclaim.html
    My Commy
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.
    Discuss.
    1989 vn white
    Jul 2011
    Wombles's Avatar
    1995 VS Acclaim
    Oct 2009
    Vs have that fault..
    My Commy
    Discuss.
    vs commodore ute
    Jul 2011
    lakehaven
    airbag light deosnt just mean the airbag may have issues. it could be another problem that uses that light to show a peroblem with the car so you take it to mechanic asap.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Airbag light means the airbag is now isolated and will not work.....this problem is usually caused by turning ignition on when dash is removed....fix is reset light by Holden or a auto elec.
    The lifted airbag cover will not affect it's operation.
  1. How to remove the front passenger side dash cover
    By nilprapai in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-07-2009, 09:08 PM
  2. Passenger side airbag cover
    By bmxer100 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-11-2006, 02:29 PM
  3. Passenger side airbag cover is pilling
    By inasinman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-03-2006, 11:33 PM
  4. Passenger side airbag cover
    By Robo70 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-06-2005, 06:54 PM
  5. Passenger side Airbag Cover
    By MattK in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-04-2005, 12:48 PM
