Results 1 to 22 of 22
Thread: VR Bt1 weird engine trouble?!
    2011 Ve clubsport
    Oct 2009
    Wagga Wagga
    Question VR Bt1 weird engine trouble?!
    Hi all!
    For some strange reason my VR Bt1s engine is being a whore! Lol. . Sometimes when i drive it hard and then pull up the oil pressure light comes on and it makes a strange tapping sound from the engine.? I turn the engine off and re start it and the light is gone as is the tapping noise? What could it be? Its really strange. If i just drive it normal i have no problem at all. Runs like a dream! But yeah every now and then after giving it a gut full this problem happens? Any help would be great!
    1989 vn white
    Jul 2011
    Warranwood, Melbourne
    1989 vn white
    Jul 2011
    2011 Ve clubsport
    Oct 2009
    Wagga Wagga
    The oil is full? It only does it now and then. Like i just gave it a little squirt this morning when i left my house and pulled up at the shops about 1k down the road and the light came on and made the tapping noise but i just put it in park and slowly increased the revs and the tapping noise got quicker with the revs then the noise just stopped? I let it idle and no problem after that?
    1989 vn white
    Jul 2011
    2011 Ve clubsport
    Oct 2009
    Wagga Wagga
    It was serviced only 3000ks ago. Could an oil filter and or using shit oil make do this tho? Its only every now and then? Today i gave it a gut full and it didnt happen? But tonight when i was coming home and passing a car it happened so i pulled over and let it idle and i slowly increased the revs and the oil light went out and so did the rattle? Ran fine all the way home? Any help would be great cause its doing my head in! Lol
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Could be 2 or 3 things off the top of my head. 1st, a blocked pickup. Sump off(engine out unfortunatly) and check the pickup isnt blocked as its been known to happen on these. 2nd, it could be the oil pump is shagged and needs replacing.
    The only other thing is it could be a blocked gallery which might lossen with an engine flush.....but if its a lump of somthing, it could lodge itself somwhere else unwanted too!
    The ticking is a very bad sign!!! that means the engine is getting no oil! I would seriously address this problem immediatly or ur engine is gonna be pretty well kaput in a short amount of time.
    Reaper
    2011 Ve clubsport
    Oct 2009
    Wagga Wagga
    I might give it a service and flush tomorrow and see how it goes? I think they put shit oil in it when it was serviced. It just seems strange because it only happens every now and then? What oil would you recommend using?
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    As above, blocked pickup is common.
    May also be sticking relief valve in the oil pump.
    Until it's fixed, dont flog it!
    I've seen one of these engines tear the front of the cam off (siezed cam) due to low oil pressure.
    2011 Ve clubsport
    Oct 2009
    Wagga Wagga
    I Dont normally flog it. . And the noise and light doesnt come on when i just drive normal. . Ill try servicing it tomorrow and see what happens. What oil should i use?
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    2011 Ve clubsport
    Oct 2009
    Wagga Wagga
    Got lifter cleaner from auto barn today and put it in. Ill service it and change the filter. What oil should i use? It just seems so strange that it doesnt make a noise and oil light doesnt come on unless the engine is pushed? As soon as the light comes on and the tapping noise happens i turn it off and re start it again and its fine? Its really starting to do my head in! Lol. But please any help would be great.
    VR Berlina
    Jun 2010
    VIC
    i had lifter ticking problems. been using nulon lifter free and valvoline engine armour semi synthetic 15w-40. after 2 changes the engines perfect
    2011 Ve clubsport
    Oct 2009
    Wagga Wagga
    Ill grab that oil tomorrow then. The car has only done 158,000ks so hopefully it cant be anything to major? As i said before it only really happens if i take off from a standing start and drive it hard until around 120kmh? The light comes on and you can hear the tapping when you stop but once you turn the engine off and re start it its fine?
  15. #15
    VR Berlina
    Jun 2010
    VIC
    well my oil light never came on but there was a noticible tapping from the valve train on cold idle and when i drove it hard. my engine had 245,000kms on it at the time. so far ive stuck with the 15-40 and it doesnt burn a drop, and with the help of the lifter free 15,000kms later on my 3rd oil change im on fresh oil with no lifter free and the engines perfect. hopefully thats all your car needs too
  16. #16
    2011 Ve clubsport
    Oct 2009
    Wagga Wagga
    Ill change the oil tomorrow night and see how it goes. Thanks heaps for the help
  17. #17
    VB SL/E
    Dec 2008
    Quote Originally Posted by 89vn View Post
    Hi all!
    Is it a V6 it's ####ed....
  18. #18
    2011 Ve clubsport
    Oct 2009
    Wagga Wagga
  19. #19
    VB SL/E
    Dec 2008
  20. #20
    RX25SE's Avatar
    vsII acclaim wagon
    Jan 2009
    Lifter noise is likely due to low/no oil pressure, as in 1st post.
  21. #21
    vs commodore ute
    Jul 2011
    lakehaven
    most standard oil pumps arnt made to compete with peak revving of the engine. either high volume oil pump or stop revving the crap out of it.
  22. #22
    vs ute
    Mar 2007
    common problem with vr v8s, oil pick up starting to block up.its about the size of a 10cent piece and doesn't take much to restrict the flow.
  1. VT 5.0 Engine 'trouble'
    By Copafield in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-07-2010, 10:09 PM
  2. Weird Engine Problem - VN SS
    By Shoxer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-10-2006, 09:26 PM
  3. vh engine trouble
    By ford fan in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 13-03-2006, 10:34 PM
  4. Vr Engine trouble..
    By aLxVR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-02-2006, 03:01 PM
  5. Engine Trouble...
    By DenchY in forum VL Holden Commodore (1986 - 1988)
    Last Post: 28-03-2005, 01:32 PM
