Results 1 to 5 of 5
Like Tree2Likes
  • 1 Post By staypuft
  • 1 Post By dat111
Thread: Do I Have to Worry About Timing When Replacing VS Heads???
    VS III V6 Ute - 5 spd manual
    Aug 2006
    Bribie Island, Queensland
    Default Do I Have to Worry About Timing When Replacing VS Heads???
    (Following the Gregory's manual) I've successfully removed the heads from my 3.8ltr Ecotec, I've got a gasket/bolt kit, had the heads checked out, and am ready to put it back together this weekend (I've never done a head gasket replacement before, but it all looks pretty straight forward).
    Some of the guys at work are saying I need to check the timing as part of the process, reading the manual it pretty much says replace gaskets, etc, bolt it all back together, and fire it up (I've kept the pushrods in the order they were removed which looked to be about the only thing the manual really cared about in terms of 'beware of this').
    Do I need to worry about the timing at all??? These guys are all 'expert', but none have ever worked on a Commodore before....
    VY SS
    May 2011
    Auckland
    I would check it just to be safe. Turn engine over with a ratchet on the crank pulley and make sure there's no interference
    VS commodore
    Apr 2011
    umina beach,nsw
    from VN dont need to be timed, there coil packs not dizzy's
    best thing holden ever did
    VY SS
    May 2011
    Auckland
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Quote Originally Posted by staypuft View Post
    In a word, no. Nothing that you will be removing to rebuild the top end of a vs v6 is 'timed'.
    Just follow your manual for the procedure order and you'll be fine.
    Cheers.
    Z' Series HSV 297KW 6lt LS2 Conversion For Sale!
    PM Me For Details
  1. Don't worry!! he is one of us!
    By Hunter SS in forum Jokes/Humour
    Last Post: 13-05-2009, 09:03 PM
  2. Replacing timing chain
    By foxtrot.tango in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-02-2007, 12:38 AM
  3. Replacing Timing Chain
    By Indy_387 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-06-2005, 05:45 PM
  4. Replacing Timing Chain
    By VTSSDUDE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-06-2004, 08:43 PM
