Well done a service on the mother in laws car today, and found the transmission oil is blacker than the engine oil. I rang the Tranny shop in Gladstone and they said it's not worth replacing the oil as its probably on it's last legs any way.
I have found a bloke wrecking A 95 VS with a rebuilt auto. He has reciepts and the price is pretty good. But just wanna find out if it will go straight into a 95 VR or will I have other things to do to get it to work?
check out my ride http://forums.justcommodores.com.au/...ad.php?t=49768
SO you changed the fluid?
What problems does the trans have?
no I have not, I took it for a drive and it is slipping quite bad
For 100 bucks or so I would take a punt and service the thing. Might go alright for another few years. But in answer to your question a VS would be an electronic trans which is controlled by the ecu so it wouldn't be a straight swap. Not sure exactly what you would need to make it work.
If the vn trans is the same as the vr then it will NOT work...
