Results 1 to 18 of 18
Like Tree2Likes
  • 1 Post By PRAVX II S
  • 1 Post By nathanVY
Thread: VS V6 Not Starting
    VS V6 Auto Wagon
    Jul 2004
    Wodonga, Victoria
    Default VS V6 Not Starting
    I can't start the engine.
    I've had guys check everything, and replace everything like sensors, fuel rail & Injectors, Fuel Pump, ECU.
    It's getting Fuel and Spark, but the Injectors aren't working.
    Auto Elec said he's never seen this before.
    Any help would be awesome.
    I have done the same Do I Have to Worry About Timing When Replacing VS Heads???
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    Sounds like the immobiliser, how old is your key? If your key is old it may not be contacting it properly...
    Not sure about all VS's but with mine, once you unlock it with the car, the interior light stays on for a set time then switches off. During that time you can start the car with ONLY a key (not keyhead etc), so if your key is playing up try starting it that way.
    vx s pack II
    Jan 2010
    aLKIDA
    The ECU sends a earth signals to the injectors. Could be the actual ECU or the factory immobilizer.
    Also the injectors should have constant power on one wire when the IGN is on this power is supplied by the EFI relay.
    So check the EFI relay and fuse.
    Also check for codes bridge pins 5&6.
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Does the security LED go out when the ignition is turned on?
    Does the auto elec have a scan tool?
    VS V6 Auto Wagon
    Jul 2004
    Wodonga, Victoria
    I'm pretty sure they have tried everything, but I'll ask.
    They've said it's not the key head, tried reprogramming the BCM
    It's a secondhand auto box, and reco heads
    VS V6 Auto Wagon
    Jul 2004
    Wodonga, Victoria
    VS Stato l67
    Mar 2009
    Melb
    Quote Originally Posted by DRAGON7 View Post
    Just a random though, did the problem start when secondhand box went in?
    VS V6 Auto Wagon
    Jul 2004
    Wodonga, Victoria
    No it ran and drove around the workshop for a while i.e moving it for space for other cars
    VS V6 Auto Wagon Green
    VS V6 Auto Wagon White (LPG), going and no Rego - needs a good tidy up
    vx s pack II
    Jan 2010
    aLKIDA
    Well if there is no injector trigger and everything else checks out i would be incline to go with the ECU as i mentioned above.
    Has the Ecu got wet anytime did someone spill a drink or has any sort of moisture been exposed to the Ecu?
    VS V6 Auto Wagon
    Jul 2004
    Wodonga, Victoria
    The ECU has been checked
    vx s pack II
    Jan 2010
    aLKIDA
    May i ask how did the ECU get checked.
    If the ECU is ok And you are not getting injector trigger maybe there is a open circuit between the injectors and the ecu wiring.
    You need to check continuty from ecu to injector wire with a multimeter.Are all the injectors not triggering?
    VS V6 Auto Wagon
    Jul 2004
    Wodonga, Victoria
    Not sure, I'll check with them
    VS V6 Auto Wagon
    Jul 2004
    Wodonga, Victoria
    I'm thinking wiring harness, anyone got a cheap one lol
  15. #15
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    Yeah i've got a complete and uncut VS berlina/calais/stato main body loom.. PM me
  16. #16
    VS V6 Auto Wagon
    Jul 2004
    Wodonga, Victoria
    I read this somewhere
    MODEL:COMMODORE
    SERIES:VR/VS
    PROBLEM:NO INJECTOR PULSE/SPARK AND FUEL OK
    POSSIBLE CAUSE:EFI EARTH CAN WORK ITS WAY LOOSE BEHIND THE DRIVERS KICK PANEL
    I'll have to check
  17. #17
    VS V6 Auto Wagon
    Jul 2004
    Wodonga, Victoria
    All fixed
    Throttle Posititon Sensor - It was reading full throttle at start up, but no code error
  18. #18
    VS Berlina
    Mar 2011
    Woodford QLD
    I refuse to believe any quality auto electrician couldnt work out why your car wouldnt start. Get your money back from the first one, and next time go to one who knows what he is doing.
  1. car not starting at all
    By crazstaat in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-04-2009, 05:40 PM
  2. Vn Not Starting.
    By K1ND3R in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-03-2009, 09:18 PM
  3. VL not starting, need help!!!!
    By treezey in forum VL Holden Commodore (1986 - 1988)
    Last Post: 15-02-2009, 08:01 AM
  4. VN not starting
    By Twitch_Dusty in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-01-2009, 09:10 AM
  5. vt ss not starting
    By djlingard in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-01-2007, 05:06 PM
