Results 1 to 8 of 8
Thread: vs belina central locking problem
    vs pursiut special
    Jul 2011
    burnie tasmania
    Default vs belina central locking problem
    i just bourght a belina and when you press the central locking button only three doors lock passenger rear stays unlocked has anybody had this problem , if so whats the answer .
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    Does it unlock?
    Mine does it on one door at random. I think it needs oiling or somthing or maybe getting stuck on the trim on the top of the door.
    two-bit's Avatar
    two-bit is offline Hiding between the posts
    vs S pac series II
    Sep 2010
    Altona
    pull the door apart and pop out the central locking actuator from the mechanism and flip the locks to see if it moves, if it doesn't dead actuator
    i had this problem in my vr calais turned out is was a gunked up lock mechanism and it was misaligned, grab some kero and give the lock mechanism a good wash let it dry spray it with some silicon spray and re align.
    VY SS
    May 2011
    Auckland
    Mine did this every month or so on the rear door passenger side.
    Just push the red bit on the lock snub back in. They pop out and catch preventing it locking. I eventually took them all off and didn't have snubs. Holden wanted like $20 each for the red bits.
    VS Berlina/ KJ Verada
    Sep 2006
    Mine does it when it rains. One I have disconnected it and the others I wrapped in plastic, I just assumed water was getting in them, doesn't happen as often as it used to.
    There's an R in Berlina
    95 VS Berlina
    http://forums.justcommodores.com.au/...ml#post1891856
    I need some statesman/ calais woodgrain for drivers side panel!!
    Drawnnite's Avatar
    Drawnnite is offline Obviously Unsensible
    2000 Vs Ute
    Sep 2010
    it could also be no power is getting to the actuator.
    in other words a break in the wire (copper not the sheath so hard to find) and this would normally occur where wires go from door into car body
    how about we make the pedals out of sticky rubber and the shoes with steel spikes. at least my shins would like that
    Quote Originally Posted by Jonesy484 View Post
    yeah i wondered the same thing when i was 4 when i grabbed the chrome exhaust of my dads rx7
    Quote Originally Posted by DM 55 WA View Post
    did you think it was a milo tin?
    vs pursiut special
    Jul 2011
    burnie tasmania
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    Let us know how u go mate.
    Good luck.
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
  1. VS central locking problem
    By patskies in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-01-2011, 09:46 PM
  2. Central locking problem
    By vk_wagon in forum VY Holden Commodore (2002 - 2004)
    Last Post: 30-11-2010, 02:19 PM
  3. VS Central locking problem
    By wickann15 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-08-2010, 12:35 PM
  4. VS central locking problem
    By the_negro_puppy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-01-2007, 11:19 PM
  5. vn belina central locking prob !!!
    By bbau78 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-12-2006, 08:22 PM
