Hi there. I have a problem with my reverse lights not working. I have changed the neautral switch and it still hasn`t fixed the problem. Today i found out they go on when u position the t-bar in the middle between reverse and neautral. So i figgure i need to adjust the t-bar or something....does anyone have any clues or ideas? Oh and they came on like that between reverse and neautral with the old neautral switch too.
BUMP
no one here has any ideas on how to adjust the T-Bar then?
im gonna go out there soon and see if i can figgure it out
There is a slight amount of movement where the switch bolts up....but I ended up bending the arm that operates the switch - use a pair of vycegrips or similar. (I also wasted my $$$ buying a new one when it only needed adjusting)
how can u adjust it when the neautral switch screws in....as far as i can tell it always comes back to the same spot when its screwed in place.
ok update....i now know what u meant "hako"....i ended up bending from inside the console the t-bar mechanism down a little and now the reverse lights are coming on when you select reverse. As easy as that!!
