Results 1 to 17 of 17
Thread: weird cooling proplem
    97 vs executive
    Apr 2011
    casino
    Default weird cooling proplem
    have a strange proplem with me engine temp, gauge reads bit over 1/4 open road driving, and and gets hot real quick around town, coolent comes back out of radiator cap, so got new cap ive had the cooling sytem flushed, new themostst, new fan realy and it still dose the same thing.
    ive tried a couple of things off other posts on here, and no luck still
    can anyone help me on this one
    vs commodore berlina
    Jul 2011
    Perth Western Australia
    I would say new radiator and hoses, and if that doesn't work get one of those pro cooling systems put in, ones used on burnout cars
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    I'd be making sure its bled correctly first, if it still does it then possible blocked radiator
    Power is measured in DECIBEL
    Phoenix21's Avatar
    Phoenix21 is offline Donating Member
    93 VR, 97 VT, 95 Statesman
    Feb 2006
    Crime bourne, Vic :P
    yer as sweetwagon said bleed up the cooling system first see how it go's then i'd be checking radiators and hoses and stuff
    VS statsman 5L
    Sep 2011
    Mackay
    hey all,
    in a way i have a similar problem. i'm always losing water but i've replaced the radiator (NEW), new hoses, new water pump and thermostat and thermostat housing and even replace the head gasket. i,ve been told the little black vacuum thing near the air filter that the heater hoses go through can leak and you'd never notice it. so has anyone had this problem and been able to fix it??
    VR BT1 V8
    Jan 2009
    Geelong vic
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by V897stato View Post
    hey all,
    That's the heater tap - easy to replace and about $35 to buy....but first make sure that is where the coolant is going. Wipe the tap with kitchen paper to see if it leaks. I hope you are using green coolant as water will corrode the internal very quickly. The overflow tank should not be overfilled - correct level is about 1/4 full cold.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by timmysvs View Post
    How much coolant are you losing and is the fan turning on when it goes above 1/2?
    97 vs executive
    Apr 2011
    casino
    im losing about 1/2 litre a week, ive changed the valley gaskets and scrubed the inlets aswell, the fan kicks in bout 3/4
    VS statsman 5L
    Sep 2011
    Mackay
    so not using coolant because it's always leaking lol and chance that the welsh plugs could be rooted and it would be leaking from them??
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Mine also kicks in at 3/4, and it heats rapidly when stopped at the lights but this is normal because when the car is stationary there is no cooling air flowing thru the radiator so the engine heats up rapidly till the fan kicks in. It should use NO coolant - mine will take a cup of coolant every 12 months and has done this for the last 7 years. Is it possible you are overfilling the reservoir? - this will then be ejected when the engine heats up and the coolant expands. Other than that, you car sounds pretty normal.
    97 vs executive
    Apr 2011
    casino
    i was playing around with cooling system and disided to take the themostat out, and its fixed all my proplems, stays cool open road driving, and gets a bit over 1/4 around town, is it all right to run it like this or will it stuff it
    VS Executive S2/ VT SS
    Oct 2008
    S/E Suburbs
    I'm no expert but usually if you take something out it's there for a reason resulting in unwanted problems? If you've found that the thermostat was the problem it sounds like you're better off replacing it rather than going without one.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Replace the thermostat! - they can actually keep your engine cooler by restricting the coolant flow at high engine revs when there is a tendency for the coolant to only flow around the front cylinders....also lack of one will increase your fuel consumption as the hotter an engine runs the more efficient it is.
  15. #15
    VH
    Sep 2008
    check low speed fan relay in fuse box ,I had same problem the fan was only running on high speed which dosn't come in till temp gets high,the low speed fan should come on when ever you turn on aircon also. relay has 5 pins and green stripe on it $10 part.cheers donhomer
  16. #16
    vs commdore 1995
    Sep 2011
    adelaide
    i had the same thing wrong it was a sensor its sits near the top hose and it controled the temp fan as well
  17. #17
    vs commdore 1995
    Sep 2011
    adelaide
    mine in peark hour it sit about half way
  1. Cooling Fan CFM
    By wamboin23 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-03-2010, 06:52 PM
  2. VS Cooling
    By Jordan88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-07-2009, 03:12 PM
  3. Oil Cooling?
    By Goon in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 19-12-2006, 01:31 AM
  4. VS air con not cooling.
    By shmity in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-12-2005, 07:46 AM
  5. Amp Cooling
    By VY2ENJOY in forum Car Audio
    Last Post: 22-10-2005, 12:54 AM
