Got the common issue of the electric side mirrors no longer working, no movement at all via the joystick.
I've got access to a multimeter, so how would I go about testing if there is power getting to the switch, ie: which pins would I measure across, and what setting do i pick if I have to test for resistance?
mine broke on the left handside. i short wired direct from the switch to the left mirror to test it out, turn out a cable had broken i the drivers door join.
Super Coach
i changed the switch in my vr to find that the problem still aint fixed, but how would i go about fixing the wires in the door if that is the case?
