Results 1 to 9 of 9
Thread: body controll module
    vs commodore ute
    Jul 2011
    lakehaven
    Default body controll module
    hey guys have a mate who has a vs acclaim. he has had trouble with it when he turns the key nothing happens andhe has to stuff around locking and then unlocking the doors again to get it to start. he was told by some one its the body control module. do you guys reckon this or something else. i sugested he clean the key which he did but still the same. aparently his control module is a medium one and there is low and high. hes having trouble finding a medium one. any help appreciated.
    nemesis_adrasteia's Avatar
    nemesis_adrasteia is offline better to reign in hell
    VR accliam, TF gemini, TC gemini, 79 isuzu ute
    Feb 2009
    longford, victoria
    sounds like the key remotes just about shagged, if it hasnt been replaced i would replace it before you replace the BCM.
    "The mind is its own place, and in itself, can make a Heaven of Hell, a Hell of Heaven."
    apparently wasting my time with 97 cubic inches
    milk doesnt come in 1.6 litres
    my geminis
    vx s pack II
    Jan 2010
    aLKIDA
    I am assuming the car does not crank at all.
    Check for codes bridge pin 5&6 see what comes up.
    Could be the Key,BCM,starter relay,or the starter motor it self.
    Does your friend have a spare key? If so give that a go.
    Feb 2009
    longford, victoria
    Quote Originally Posted by PRAVX II S View Post
    the way i read it was it starts if he locks then unlocks with the remote.
    my geminis
    vs commodore ute
    Jul 2011
    lakehaven
    yeah tryed the code trick and its saying all is fine. he bought a new remote and still the same thing. the only way it will start is if he sits in the car. remote locks the doors and then unlocks them again and then he can start the car. otherwise there is no cranking power at all.as if the battery is flat but still has a good battery in the car. he even had the ignition barrel replaced but still no go.
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    Sounds like it is not making contact with the ring that goes around the ignition keyhole. There is metal part that is on FOB (key head) that has to make contact with that metal ring otherwise it will not crank at all....
    If it is making contact then I would assume that the wire is broken that is connected to that that metal ring,
    vs commodore ute
    Jul 2011
    lakehaven
    yeah he thought that but he cleaned it all and still no good. im not sure if it was replaced when they changed the ignition barrel though.
    James39's Avatar
    Jul 2009
    Newcastle NSW
    Quote Originally Posted by favsute View Post
    You would have to take the steering wheel colum cover off to check that there is a wire connected to that metal ring... If you are lucky it may have just come unplugged.
    By the sounds of things thats where the problem is, since he was messing around in that area.
    vs commodore ute
    Jan 2010
    nsw
    this happened to me it ended up being the bcm i checked the codes but nothing come up at first but when the car was left unlocked for a while without unlocking and locking the car a a code come back it was the theft deterant signal was missing if you have'nt already check the codes when the car has been unlocked for a while
  1. where is the vq body control module
    By DOWNVS in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-02-2011, 01:19 PM
  2. body control module
    By tigersrule in forum Electrical Wiring / Questions
    Last Post: 25-08-2010, 01:20 PM
  3. body control module
    By ausrs in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-06-2009, 03:50 PM
  4. Body Control Module
    By BerlinaV8 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-05-2009, 03:49 PM
  5. what does the BCM (Body control module) do???
    By muggo05 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-02-2009, 01:24 PM
