Results 1 to 14 of 14
Thread: Bonnet hinge sag
    VB SL/E
    Dec 2008
    Default Bonnet hinge sag
    I have seen second gen commodore hinges sag to the point of cracking the windscreen when the bonnet is lifted, what is the preventative maintenance and rectification for this?
    Not_An_Abba_Fan's Avatar
    Not_An_Abba_Fan is online now Exhaust Guru
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Lubricate the hinges. They get dry and the pin pops, causing the corner of the bonnet to hit the windscreen.
    Visit my Facebook page
    VB SL/E
    Dec 2008
    I do lube them and they are operating smooth but the bonnet sits a few millimetres low at the back which I thought was sag, I maybe able to adjust it up but don't want to band aid the problem, is new hinges the only fix?
    Is it the pivot points?
    What to look for in used hinges?
    scvs6's Avatar
    scvs6 is offline Donating Member
    1995 Holden VS Berlina 3.8L Supercharged V6 L67
    May 2011
    Ballarat, VIC
    I was also wondering about this. The bonnet on my VS sits low at the back and people keep mentioning it to me but I don't know how to fix it.
    Quote Originally Posted by Jasper44
    For all you kids out there, when your about to have sex, just remember that it would be better if you went out and shot a police officer with a bazooka instead.
    Including car parts (VS, VT, VX, VY, WH etc), my WH Statesman, and other things listed on eBay.
    WL CAPRICE
    Mar 2011
    I'd like to realign mine as its got a big gab between the guard on the left near the lights and a very small gap on the right again near the lights.
    But don't know how to go about it.
    VB SL/E
    Dec 2008
    Quote Originally Posted by CAPRILICIOUS WL View Post
    Sounds like you are going to crack the screen soon, how is the height alignment between the guard and bonnet at the windscreen?
    maybe a new set of hinges for you...
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Whatever you do, be carful if you try to remove the bonnet and get to the hinge. The hinge will fly open and slap onto the front window...and crack it. Just to be safe slap a few bed pillows on the windscreen before you start just incase.
    Reaper
    VB SL/E
    Dec 2008
    VrWagz1's Avatar
    May 2008
    wollongong
    hmmmm, got me there....maybe im thinking of another make car
    Reaper
    WL CAPRICE
    Mar 2011
    Quote Originally Posted by VR38 View Post
    The height is fine it's just a gap on one side next to the headlights and the other side has a tiny gap is almost gonna touch.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    You can adjust the mud gaurds a little to give the bonnet a more even gap on each side - I've done it several times to the VN's when re fitting bonnets.
    As for the bonnet sagging at the rear next to the windscreen - the hinges are bent. Fit new hinges to make the bonnet sit level again.
    and 3 Dangerous non ABS VN's
    VP Exec
    Jun 2005
    While new hinges are best and easiest it may be worth playing with the old ones.
    If you place something like a block of wood inside the parallelogram described by the hinge that will stop it from closing and you will be able to bend the part that the bonnet bolts to relative to that. Be careful closing the bonnet after any adjustment of course.
    I'd probably just go ahead and fit the new hinges though.
    VB SL/E
    Dec 2008
    There does not appear to be any bent parts in the hinge but then closed I can lift the left hand side next to the window, can actually rattle it up and down.
    VP Exec
    Jun 2005
    So, unless the bolts are loose, the pins are worn and you need (a) new hinge(s).
  1. VP Bonnet Hinge
    By votality in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-05-2011, 07:41 PM
  2. bonnet hinge bolts
    By Panama in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-04-2008, 06:54 AM
  3. bonnet hinge problem
    By PCJ in forum VL Holden Commodore (1986 - 1988)
    Last Post: 24-03-2007, 01:07 PM
  4. Tightening bonnet hinge(body end, not bonnet end)
    By NOGEN 3 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-03-2007, 11:28 AM
  5. broken bonnet hinge
    By Dezza in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-10-2004, 02:11 PM
