Results 1 to 4 of 4
Thread: vs diff oil strange colour.
    alan smithy is offline alan smithy
    vs wagon
    Aug 2008
    footscray melb.
    Smile vs diff oil strange colour.
    hi all, just thought i'd check diff after 4 years.(ok i am a bit slack) level was ok but it was a yellow colour and frothy.it was warm so does that account for it being frothy?
    i guess bottom centre bolt is a drain plug. is it normal or should i drain & refill?
    thanks all for any response.
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    A VS you have to remove the whole cover plate to drain (that non IRS), its normal to get a little frothy but should only be a little bit on top of the oil. Yellow is a strange colour, should be a golden (ish) colour when new and will slowly get browner and blacker as it ages and gets contaminated. I would suggest you change it just to be on the safe side, make sure you purchase a Hypoid compatible oil other wise you get extreme frothing and then poor diff lubrication resulting in failure. Pretty sure they take 80w-90 for general use or 80w-140 for heavy duty.
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    thats not right unless its some sort of wierd super oil. Unfortunatly the bottom bolt is not a drain, you need to loosen all the cover bolts and pop the cover off. However you need new gasket and everything then. Best way is to go to an auto store and buy a little hand pump and pump the old oil out through the filler hole, then you can use the same pump to pump it back in, as its a bit hard with a funnel.
    Reaper
    Not_An_Abba_Fan's Avatar
    Not_An_Abba_Fan is online now Exhaust Guru
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Sounds like it has had water in it if it went yellow and frothy. Check the teeth to see if they are pitted.
    Visit my Facebook page
  1. Replies: 7
    Last Post: 06-07-2010, 01:55 AM
  2. 304 I need a new diff.. well I want a new diff..and mine's noisy..so..I need a new diff.
    By Warranty Void in forum V8 Development and Modification
    Last Post: 24-05-2010, 02:19 PM
  3. Strange, strange problem.
    By Morton in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-01-2007, 05:26 AM
  4. Colour chart/colour guide
    By aurz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-05-2006, 07:21 PM
  5. Strange
    By Steven M in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-11-2005, 03:51 PM
