Results 1 to 24 of 24
Thread: Car won't start !?
    jtwizzy's Avatar
    jtwizzy is offline [SNWYZ]
    Holden VS calais
    Feb 2006
    Exclamation Car won't start !?
    Hey guys ! ... recently bought a VS calais with an ecotec, 140,xxx on the car, fairly clean and stock as a rock, perfect start for a project !
    First couple of days she was all sweet then decided to stop starting
    It's been at the mechanics, has had a brand new crank angle sensor, fuel pump and filter & DFI module fitted
    After all those parts where fitted it started ( success ! ) then it was turned off, not long after it was started again to move it around the workshop but won't turn over !?
    Has half a tank of fresh fuel, new battery etc
    The mechanic is stomped on what it is ?! ... His thinking a bad earth even ?! ... He checked the codes and it's all fine, has fuel and spark as well.
    Any help would be greatly appreciated !!
    Josh
    VS
    Jul 2010
    Sunshine Coast, Queensland
    jtwizzy's Avatar
    Holden VS calais
    Feb 2006
    VS
    Jul 2010
    Remove the fuel lines from the back of the rails. Turn the ignition on. If fuels coming out, then put them back on and try the injectors. Fuel makes it past that, test all your sparking areas.
    ephect's Avatar
    ephect is online now Donating Member
    VS Acclaim V6
    Jul 2006
    Quote Originally Posted by seq4x4 View Post
    Please do the reverse, test spark first then fuel.. no fire is needed. Or wait until the excess fuel is dry or cleaned off thoroughly.
    Could be pump has shit itself.
    So it's cranking but it won't run? Does it sound like it wants to start?
    jtwizzy's Avatar
    Holden VS calais
    Feb 2006
    tryed all as above and still nothing ?!
    tried 3 different ( brand new and old ) crank angle sensors and still nothing !?
    where suspecting next that it could be a ecu ?
    ephect - it's cranking but doesn't want to turn over ... it did yesterday for like 5 mins, coughing and spluttering and back firing and now it won't start at all ( still cranks )
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    Holly hell a VS with an ecotec, they are about as rare as the next vs v6 with an ecotec...... As for you're problem I would be checking you're injectors, doubtful it's you're ECU but that is not to rule it out as you're ECU basically turns on you're injectors. You had the DFI module changed but not the ignition coils?
    If it's not a Symptom its not relevant, and if its not relevant I don't care!
    vx s pack II
    Jan 2010
    aLKIDA
    So you said you get spark and have changed the fuel pump.
    Do you have injector trigger? If there is no injector trigger the fuel is not going in the combustion even though the fuel pump is working.
    Check for spark first. then fuel pressure then injector trigger/pulse.
    jtwizzy's Avatar
    Holden VS calais
    Feb 2006
    Black_Stig - if i was looking for sarcasm i'd ask this question on another forum with people who have no experience ... ignition coils where done before i purchased the car
    PRAVX II S - Will check that tomorrow bud !
    jtwizzy's Avatar
    Holden VS calais
    Feb 2006
    So the car has everything
    Spark, injector pulse, etc etc
    Checked the tank with the lines off to see if it was pumping fuel and nothing
    replaced the fuel sender as the pump was brand new ... car started for 5 mins then started to cough and splutter etc and died
    tried to start again and went back to its same state of just cranking
    listened for the pump to prime and it's not doing it ?! yet the sender was replaced along with a new pump and it was fine for 5 mins idling !? and now won't start again
    ready to give up lol
    tips ? ... pointers ? ... anyone ?
    holden vs ute
    Aug 2011
    brisbane
    hmmmm its sound like could be have problem with coils or fuel filter could be old?! did ur car have backfire alot?
    jtwizzy's Avatar
    Holden VS calais
    Feb 2006
    fuel filter has been replaced as have the coil packs
    the car back fired on the first start last night then was ok
    idled for 4 / 5 mins then started to hunt and bog down
    tried to keep the revs up then the car died and didn't wanna start
    after that i put my head under the fuel tank whilst the missus turned the car to accessories and i didn't hear anything from the fuel pump
    checked relays and swapped them with other ones ( horn etc )
    still nothing
    tried again after work and still nothing
    vx s pack II
    Jan 2010
    aLKIDA
    Quote Originally Posted by jtwizzy View Post
    still nothing
    First off mate it should be on IGN not Accessories to turn the fuel pump on.
    Also check if the PCM is sending a signal out to the relay to activate the relay and fuel pump
    The wire from the PCM sends a power signal with (IGN on) you can check it at the PCM or at the relay socket.
    No matter if you change the relay over if there is no signal the relay will not energize
    jtwizzy's Avatar
    Holden VS calais
    Feb 2006
    Sorry mate i meant IGN lol
    we checked if the relay socket was getting power over the weekend and it was
  15. #15
    Wombles's Avatar
    Wombles is offline Cars cost too much.
    1995 VS Acclaim
    Oct 2009
    You need 3 things to get combustion.
    You have spark yea?
    You have fuel?
    Maybe check the sensors for the air intake?
    http://forums.justcommodores.com.au/...e-acclaim.html
    My Commy
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.
    Discuss.
  16. #16
    vx s pack II
    Jan 2010
    aLKIDA
    Ok then the relay energizes
    Is the power getting to the fuel pump. Check with IGN on and get a test light and probe the power wire at the fuel pump.
    I think its the violet wire.
    Check the earth at the fuel pump as well.
  17. #17
    jtwizzy's Avatar
    Holden VS calais
    Feb 2006
    So i changed my fuel pump to original one that was in it in the first place
    fuel pump primed, started and ran for half'n'hour with out skipping a beat ! ... had the engine light on the whole time but i think that was to with the thermo not being hooked up ? (was already off due to wanting to change the radiator)
    took it for a gentle drive around the block and all ok !
    pulled up out the front of my place, turned it off and tried to start it again and all it was doing was cranking again with no kick over
    checked to hear the pump priming and it is every time
    am i going crazy ?! ... im a little over it now lol
  18. #18
    vx s pack II
    Jan 2010
    aLKIDA
    What is the fuel pressure on the fuel rail while cranking and with IGN on?
    Are the injectors ok check for the resistance of the injectors. Probe the injectors with multi-meter leads. Disconnect the
    injector terminal.
    I think its meant to be between 11.8-12.8 ohms. I know this is for the vt-vy.
    Also you stated that the fuel filter was changed is it put in the right way flow wise.
  19. #19
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I've seen this problem caused by a faulty oil pressure switch which got wet when degreasing - the internals fail which results in no power to the fuel pump. (the oil pressure switch supplies power to the pump) It can be intermittent. Easy to check by substitution.
  20. #20
    vx s pack II
    Jan 2010
    aLKIDA
    Quote Originally Posted by hako View Post
    Yes this could be the problem.
    But the oil pressure switch is not the main power supply for the fuel pump.
    You will find that the fuel pump relay is a change over type.
    Say the fuel pump fuse blows the fuel pump will still operate via the oil pressure switch (change over relay)
    So long as the oil pressure is adequate.
  21. #21
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by PRAVX II S View Post
    I've never fully understood this, or found anyone who can properly explain how power is switched from the FP relay if the FP fuse blows - the relay coil is on a separate fuse to the pump and will still be in circuit with the pump despite the fuse being blown.....how then does it 'change-over'?
    But that aside, there have been many similar instances where the OP switch has shorted internally and caused this very problem.
  22. #22
    jtwizzy's Avatar
    Holden VS calais
    Feb 2006
    found a solution
    sold it tonight
    going back to a jap car as there more reliable
  23. #23
    1996 vs v8
    Aug 2011
    auckland- new zealand
    gutted i was hoping you would have found the problem as mine is doing pretty much the same thing! but not intermittent, just wont fire
  24. #24
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    found a solution
    sold it tonight
    Oh well your loss, their gain
  1. odometre stop start stop start???
    By The pig in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-07-2011, 06:35 PM
  2. vs calais wont start unless i kit unlock before i start
    By scottmcguinness172 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-05-2011, 06:40 PM
  3. Wouldn't start when warm, now won't start at all
    By karwalski in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-05-2010, 06:18 PM
  4. Won't start without "start ya bastard"
    By Steven M in forum VL Holden Commodore (1986 - 1988)
    Last Post: 08-11-2005, 12:12 PM
  5. Can't start cold except for clutch start.
    By Holdfast in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-08-2005, 07:30 PM
