Hey,
Probably a stupid/obvious question; what are the two barbs on one of the tanks on the radiator for? Are they to run as a trans or p/s cooler as well?
CHECK OUT MY RIDE
http://forums.justcommodores.com.au/member.php?u=62088
Tranny lines. Theres a P/S cooler?
If you have a manual, you won't use them.
Thought so, yeah I have manual, does it cool fluid very much? I'm thinking bout running p/s through it if the cooling is decent enough.
CHECK OUT MY RIDE
yip, oil cooler for your Auto...
VS V8 Manual ... Reppn it for NZ
Cause it gets extremely hot as you know specially when going hard and am sick of it leaking and overflowing. Specially once I put new pump on, wanna give it a good life and why not optimise the barbs in radiator?
CHECK OUT MY RIDE
