Results 1 to 2 of 2
Thread: VR Brake Problem
    vs ute
    Mar 2007
    Default VR Brake Problem
    lately ive noticed the brake pedal on my vr v8 getting harder to push, there is a lack of assistance from the booster. i tried a test where you pump the pedal for about 30 seconds and then start the car, the pedal then drops slightly and then stays in that position.From what i have read this is supposed to happen.
    what i do know is the revs go up slightly if you pump the pedal when idling?
    2nd problem that i found is the clamp for the vacume hose that goes into the intake manifold is sitting back about 10mm further than it should and is jammed against the coil.
    I think this may be leaking at the clamp, which it looks nearly impossible to get at.
    what's you ideas on this?
    Rusty's Avatar
    Rusty is offline ٩(-̮̮̃•̃)۶
    304 Ute, WRX Impreza
    Mar 2010
    Queensland
    I cannot really help as far as fixing it but I definitely recommend going to get it looked at by a professional ASAP! Brakes are about the only thing I will not play with and for a damn good reason!
  1. Brake Problem
    By luke_vs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-03-2011, 09:01 PM
  2. VT - Brake Problem!
    By ironwool in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-11-2010, 09:50 PM
  3. Brake problem
    By Ryan Mckd in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-04-2008, 04:49 PM
  4. Brake Problem
    By FINCH in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-02-2006, 12:37 PM
  5. Brake problem
    By tkaragia in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-02-2005, 09:42 PM
