Results 1 to 7 of 7
Thread: Vs cai
    spud_22's Avatar
    spud_22 is offline Ruled by the P
    95 VS Berlina
    Nov 2010
    Default Vs cai
    Have the chance to get an VS SS CAI cheap are they worth it or is it better to save up and get a mace CAI.
    3.08 LSD, 1.9.1 High Ratio Rockers, MACE CAI, Spacers
    ephect's Avatar
    ephect is online now Donating Member
    VS Acclaim V6
    Jul 2006
    Get it, if it's cheap enough. No reason why u can't use it until u want to go for the mace cai and sell off the standard one after.
    IMHO stick with the vs sc intake unless it's worked to the max, u won't require the mace one.
    spud_22's Avatar
    95 VS Berlina
    Nov 2010
    Ok well i can get it for about $30 so might aswell.
    VS 5 Litre BT1
    Jul 2006
    Try reading the MACE CAI thread, in particular the test conducted by Immortality for a comparison of the two.
    MACE Cold Air Intake
    Heat soak appears to be the issue with the Holden CAI set up.
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    So the mace device is half an air box that allows for air to be pushed to it from the high pressure zone in front of the head light, so it's not a cold air intake as such. The benefit as I can see is less heat soak with the mace because it's not sitting on top of the radiator
    30 v 250 no brainer for me imho. Heat soak on the road is nothing, it's only in traffic.
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    I`ve had both mate.
    Mace one is better.
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    VU Ute 3.8 S
    Mar 2011
    Their you go Shane.
