Results 1 to 7 of 7
Thread: Vs V6 rough idling when in DRIVE
    vnv6gee is offline vnv6
    Vn series 1 calais
    Jul 2009
    Default Vs V6 rough idling when in DRIVE
    Hi guys i got a vs v6 just serviced it completely new plugs new leads new oil new filter the whole lot and when the car is in drive and you are at a complete stop it idle really rough i have changed the idle air speed sensor changed the air flow meter dont know what else to look at if anyone has any info on they think it might be it would be appreciated
    cheers
    1996 Holden VS Berlina Series II
    Jan 2011
    If you've ever had the exhaust done/fixed there's a good chance the exhaust rubbers holding it in place are a bit too tight. The exhaust is supposed to move a bit freely as it vibrates a lot and if too tight up against your car your whole car will have idle vibration.
    I've got a minor idle vibration in drive and reverse on my vs and I reckon it's that, just couldn't be bothered doing anything about it as it isn't that bad.
    I could be wrong though.
    VY Clubsport R8
    Sep 2010
    sprayzz's Avatar
    sprayzz is offline sprayzz
    vs commodore
    Dec 2007
    Quote Originally Posted by vnv6gee View Post
    cheers
    my mums car had the same sorta problem when at a stop light or somthing it will stall occasionally was so rough lol it was the fuel filter could maybe be that
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    Did you clean you're throttle body and the TPS? Could be a vacuum leak somewhere, also a possibility of stuffed Engine Mounts. Never heard of exhaust's needing to have a bit of movement in them to stop vibration. Last I heard the exhaust needs to be firm and in place.
    If it's not a Symptom its not relevant, and if its not relevant I don't care!
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Bad earth to the DFI will cause rough idle and a near stall when shifting from reverse to drive.
    VS uses ignition timing as well as IAC to control idle speed.
    VS Berlina/ KJ Verada
    Sep 2006
    Mine used to idle very roughly when stopped at lights and nearly stall changing from drive to reverse. Afte taking off my inlet manifold I found the gaskets were absolutely rooted so I put new ones in, cleaned it thoughly and the TB and I swear now a house of cards would sit undisturbed on my block. Something to consider perhaps.
    95 VS Berlina
    http://forums.justcommodores.com.au/...ml#post1891856
    I need some statesman/ calais woodgrain for drivers side panel!!
  1. vt ss 5l idling very rough
    By whitey0 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-05-2011, 08:30 PM
  2. rough idling
    By mauriced in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 05-06-2009, 06:59 PM
  3. idling rough
    By homer simpson in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-10-2007, 06:20 PM
  4. VR rough idling
    By jimmy80 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-07-2005, 11:27 PM
  5. idling rough
    By ken & hank in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-07-2005, 10:30 PM
